BACKGROUND IMAGE
BACKGROUND IMAGE
how can i place a background (for example an image) in indigo?
Give me printscreen please because i have already tried many settings in blender and indigo.
I think that it should be with an exr.file but i can't make it!
i'm not really a beginner, for example:
I have well understood
uv maps
lights
export
launch indigo
thanks in advance! Can i have please an answer as soon as possible because it's an work in process.
uv maps
lights
export
launch indigo
- afecelis
In the exporter options; change "Env Type" to "map", change it from "spherical" to "LatLong" and type in the name of your .exr image. The exr image must be placed at he same folder level as your xml.
That's it!
ps. you can convert hdri images to exr using the command line tool hdr2exr; grab it here:
http://hem.bredband.net/b230591/hdr2exr ... _win32.zip
ps2. Also check this thread:
http://www.indigorenderer.com/joomla/fo ... ht=hdr2exr
so also remember to use the search function as many of the questions have already been solved.
That's it!
- afecelis
Not sure but I think it has to do with the format of the hdr you're using. Is it a spherical probe? Try using a LatLong hdri instead, or convert your existing one to LatLong using HDRSHOP free. Or simply try with another hdr image and if it works try comparing them both to see what's different among them. Also, Indigo likes latlong exrs better; with spherical ones it crashes
Remember it has to be done thru a command line window (DOS mode) so it would be cool if you add the executable of hdr2exr to your system's PATH environment variables so you can invoke it from anywhere in your PC. Then all you gotta do is CD (change directory) to the folder where you got your hdri, and simply type "hdr2exr myimage.hdr myimage.exr" and you're done!
ps. Nice hood!! hehehehhe
- afecelis
the evermotion free maps are latlong; I've converted some of them to exr with no problem. Weird.
here's sky0050 converted for you to try:
http://afecelis.gdlib.net/Indigo/sky0050.zip
- afecelis
Link to the "converting hdri images to exr" tutorial:
http://www.indigorenderer.com/joomla/fo ... php?t=1071
hope it helps!
hope it helps!
Hi, ive got a last question about those hdr maps, there's any chance to get more sharpness, on that sky's(?) because it looks little pixelic.
Here's my test scene where is that sky.
http://img120.imageshack.us/img120/8370 ... 394gx9.png
Users browsing this forum: DotBot [Bot] and 10 guests
