A get a little problem with skindigo or sketchup I'm not sure about that...
I was working on a scene that was not very complicated with 5-6 different indigo materials.
When I tried rendering, nothing happened. Much clearely, I could see the "Writing mesh ...." in the status bar but suddenly it stopped and nothing happened.
I tried exporting the scene to open it directly in indigo. I saw this message :
The end of the file in attachment. Open it with a Bloc-note's style programme. I was not sure how to interpret that but I purged all the UVs sets of every faces in the UV mapping of skindigo and then it worked...Error: There was an error with the scene file: failed to load XML doc from path 'C:\Users\Johan\Sketchup\Architecture\Usinae\Usinae-meshes.igs': Error reading Attributes. (Line 79848, column 44.)
But it started again later when my model became more complicated and I still haven't found any efficient solution now.
What am I doing wrong? Can someone help?
Edit : I'm working with skindigo 2.0.12 et the latest indigo
