Indigo 2.2.3, with Mat Editor beta 2
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_2.2.3_Setup.exe
Changelog:
2.2.3:
* Mat Editor: Changed unit of bump and displacement from m to mm.
* Mat Editor: Sub-type controls created on the fly to speed up GUI.
* Mat Editor: Gave shader controls simple default shaders.
* Mat Editor: Made more user-friendly names for material types and parameters.
* Mat Editor: Hidden light layer controls.
* Mat Editor: Combined Render and Restart Render actions.
* Mat Editor: Settings saved (for limited time at least) when changing material types.
* Mat Editor: Added texture preview image in texture control.
* Mat Editor: Stopping render if scene error encountered.
* Mat Editor: Added options dialog.
* Mat Editor: Last browse path (for textures etc..) is now stored.
* Mat Editor: Max one medium is now used per material file.
* Mat Editor: Render/Restart Render has keyboard shortcut Ctrl+R
* Mat Editor: Fixed upload filename not having .pigm extension if mat file not saved.
* Mat Editor: Added shortcut and file associations for .igm and pigm to the installer.
Changelog:
2.2.3:
Re: Indigo 2.2.3, with Mat Editor beta 2
Please check the file. I get an installer error. Already downloaded
two times just to be sure. Thanks! ;o))
take care
psor
take care
psor
Oops, connection got broken half way through, re-uploading...
re-uploaded.
Thanks, checking out ...
- Doug Armand
Possible bug
Download the Candle wax material from the Material Database and start render. Looks nice and white.
Now select the wax medium. Dont change any settings and restart render. The render now looks yellow. I thought it was because I had just the medium selected but it happens even if you reselect the main material.
Seems if you change the focus to the medium it stays there even if it seems to have changed focus?
Thanks for the other changes though Ono - in particular remembering files locations :-)
Yup, there's a bug with absorption colour. I think it's forcing the gamma to 2.2 when it should be 1. Will fix.
Thanks!!
Any indigo 2.2.3 bug fixed list? if there're some bug fixed...
UI, as in indigo renderer looks awful ... I hope to be in the plans for making a decent graphical UI? ;)
Everything is too big ... Only a few functions and the need to scroll sliders ...
I realy appreciate ; )OnoSendai wrote:* Mat Editor: Combined Render and Restart Render actions.
1) I can't "open" more than one material. I can open a downloaded file and create another one to blend but I can't have 2 downloaded material in my material list... would be appreciate too
edit: 2) would be nice to choose file or folder name when I download material. I did download 4 material and I just don't know which folder match to material. Would be nice too to choose folder directory too.
thanks in advance
- pixie
Sometimes I wonder if UI wise I the QT framework is that much flexible for what it has to accomplish...zed_pmd wrote:UI, as in indigo renderer looks awful ... I hope to be in the plans for making a decent graphical UI? ;)
Ui indigo is inconvenient and tiring ... particularly light layers
- Doug Armand
Personally I find it fine. Indigo is really just a renderer - a very excellent render :-).zed_pmd wrote:Ui indigo is inconvenient and tiring ... particularly light layers
How good an interface does it need?.
If was a modeller/animation program then you might have a point with your complaining :-^)
However, Indigo is a commercial product. In my opinion, should keep a good level of performance. It is true that it is a very good product but what prevents that was even better? ;)
I am also the first who asked for such amendments. Well-designed menu makes it easy work - it becomes more enjoyable and more efficient
I consider buying a license so I ask for different things such as, for example, vignette control (yet did not receive a reply)
Vignette control is a long time request, we're all waiting for some answer. I guess Ono and Benn are considering if (and how) it is possible to implement.
About a more intuitive and smart layer control, I agree with you. But some purpouses are already been posted, we're only waiting for the new GUI. I think there are some more critic issues to be solved before a mere graphic improvement.
Users browsing this forum: No registered users and 87 guests
