When playing around with my kitchen scene, suddenly blendigo didn't export it correctly anymore. I have multiple cameras and layers on the scene, and blendigo seemed to lock on only one combination (i guess that was camera 1 and layer 1, but I'm not sure).
This pretty much rendered the whole scene useless, so some kind of solution would be appreciated...
Blendigo doesn't export scene correctly
Re: Blendigo doesn't export scene correctly
Any screenshot?
Here's a screenshot.
On the left is the situation before exporting, on the right is what i get...
Luckily i got backup-file of the scene (just got a new computer and had the old file on my older one...), so almost no damage was done.
I played around with different views and had the Blender 3D-window divided so that on one part there was view from camera one and on another from camera 2. I guess the lock-up happened when i closed one of the 3d-windows.
Now that i look at it closer, the same problem affects Blender internal too, so it seems to be Blenders problem, not blendigos... So don't mess with 3d views when having multiple cameras!
- Untitled-1.jpg (277.02 KiB) Viewed 2534 times
Yes - i haven't tried to do multiple cameras with Blendigo. Lovely looking scene though - have you had any other problems / questions with Blendigo?
You can set the active camera by selecting it and pressing ctrl+numpad0, or in the header of your 3D-View select View->Cameras and then select your active camera there.
If none of these works I would guess your file is broken, try to append the whole scene to a new file and see if it works there.
Your ad here!
I tried doing exactly that, but the file is apparently broken. Luckily I had backup for the file, so no harm was done.
Users browsing this forum: Google [Bot] and 2 guests
