still problems with ex3ds undefined
Are all the objects editable mesh? are there any splines or shapes in the scene (not sure but i think those can screw it up)
Website
http://www.surrient.com/
I dont have Viz 2007, but i opened the scene in Max 8. It complained something about missing dwg plugin, but i got the scene loaded.
You have a huge list of objects, that dont have any material assigned at all. That's where the ex3ds error comes from. I dont know how can i send you the list of those objects? I cant export the list from selection screen or anything and the list is too big for screenshot. You can try to assign one indigo material to everything and see if the error goes away. Then start building the scene materials from ground up.
BUT i couldnt get the scene to render. After solving ex3ds error i got another one - Mesh operation on non-mesh: Block/Style Parent.
I think it is related to importing the Autocad file. If i looked at the object list, then there was a funky parent-child relationship between most of the objects. Maby thats because i didnt have that dwg plugin or something.
Also check out this thread - http://www.indigorenderer.com/joomla/fo ... n&start=15
It appears to be a similar problem.
Maby it helps.
Suvakas
Maby it helps.
Suvakas
?? well OK the >< could be a problem .. but this will be in the nextradiance wrote:i've found some more bugs:
<!--object Box01 <box> box -->
<mesh>
<name>Box01 <box> box</name>
- it seems < and > signs in object names go into the xml and produce parsing errors. autocad linked objects always have <> in them...
- -- unknown system exception.
even when removing EVERYTHING from that max file i posted before,
and leaving 1 object remaining (a propper editable mesh) it still won't export. i just get a unknown system exception message.
the exporter works fine though if i start a new scene and add some meshes.
Radiance
version...
cheers
u3dreal
