Blendigo 2.2.1 for Windows
Attention: Updated 16.09
*fixed camera rotation
*fixed start frame for cam/motion blur
Installer:
http://www.indigorenderer.com/dist/expo ... taller.exe
Zip Archive:
http://www.indigorenderer.com/dist/expo ... -2.2.1.zip
Changelog:
* thread priority fixed
* mesh subdivision fixed
* animation fixed
* check if no UVset in mesh
* camera motion blur fixed
Installer:
Zip Archive:
Changelog:
* animation fixed
Check normals, dude!
- cooler_inc
Re: Blendigo 2.2.1 for Windows
W7 (64)cooler_inc wrote:Thx
Blender 2.49b -
"Python scrypt erro: check console"
Visual C++ 2008 SP1 installed...
then check consolesger wrote:W7 (64)cooler_inc wrote:Thx
Blender 2.49b -
what version of python do you have installer? i've seen you have 2.5. Blender 2.49 needs 2.6
- Borgleader
If I may suggest something SmartDen, from now on you should put up a list of the appropriate (or rather required) version of Python for the Blender version people are using, as I'm sure this will be a recurring problem, especially with Blender 2.5 coming up (which requires Python 3.1).SmartDen wrote: then check console
Just to remind people
I always did before, but nobody seems to read what i'm writing in requirementsBorgleader wrote:If I may suggest something SmartDen, from now on you should put up a list of the appropriate (or rather required) version of Python for the Blender version people are using, as I'm sure this will be a recurring problem, especially with Blender 2.5 coming up (which requires Python 3.1).SmartDen wrote: then check console
win -64
Python - 32
Blender - 64
bit
Python - 32
Blender - 64
bit
- mist_python_edited.gif (39.87 KiB) Viewed 12589 times
third line in the blender console says: No installed python foundsger wrote:win -64
Python - 32
Blender - 64
bit
- Doug Armand
Just a quick post to say the installer worked fine and Blendigo loads nicely with Blender.
This is on Win 7 RC x64.
Will check out motion blur in more detail later but thanks for letting us set Thread Priority again - and yes that works fine
Doug
Doug Armand
Doug Armand
- Borgleader
Hard to put it any better, however it is possible that Python is actually installed but there is no environment variable for it and so, it's not finding it?SmartDen wrote:third line in the blender console says: No installed python foundsger wrote:win -64
Python - 32
Blender - 64
bit
My hunch is that it's the wrong version and architecture.
Your python says 2.6.2 32 bit, but blender says 2.6.1 64 bit.
Blender 2.4x doesn't know how to automatically detect the installed python - you have to set an environment variable.
From the Blender Manual ( http://www.indigorenderer.com/dist/plug ... Manual.pdf ):
Follow the following instructions on how to set the PYTHONPATH environment
variable. This is necessary so that Blender knows where your Python
installation is located:
http://wiki.blender.org/index.php/Doc:M ... thon/Setup
hmmm...not working for me:
Vista SP2 32bit
Blender 2.49b
Python 2.6.2
console output:
Compiled with Python version 2.6.2.
Checking for installed Python... got it!
File "<string>", line 1, in <module>
File "C:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\.blender\scripts\blendigo.py", line 54, in <module>
modulesPath = os.path.join(Blender.Get(u"scriptsdir"), "blendigopkg")
File "C:\Program Files\Blender Foundation\Blender\python26.zip\ntpath.py", line 96, in join
assert len(path) > 0
TypeError: object of type 'NoneType' has no len()
also tried to reinstall blender, indigo and blendigo
Vista SP2 32bit
Blender 2.49b
Python 2.6.2
console output:
Material Preview is broken for me.
I think there was a thread somewhere how to fix it?
Any ideas?
Any ideas?
Your ad here!
