I had a little testing session last night. I hope you release some tuts about the use of shaders soon
Yep, the center is in focus. I can see, that the extruded thing on top of his head is sharp. That means, that your focal point is well.. in the center of the statue. You should not place it to the center, but to the same level with the frontal part. If you are taking a picture using a real life camera, then you can't focus to the center of a person. You would have to focus to some other body part like nose, face, etc. Hard to explain. You have to move your target a bit back towards the camera to the same level with the face or smth.Pibuz wrote:Yes indeed. That's odd by the way, because I put the target of the camera right in the center of the subject..![]()
By the way, first tests: don't expect too much from them
Users browsing this forum: No registered users and 52 guests
