Custom Indigo Material
Re: Custom Indigo Material
Post by fused » Thu Aug 20, 2009 11:23 am
its getting even better, David :)
along with the new material i was planning to do a custom material preview gui element which automatically updates the preview image every x seconds (probably 10) when the material is opened in the material editor or AM.
here we go. i present to you the new progressive preview:
you will of course be able to adjust the size of the gui element. indigo console runs in background. im not sure yet how this is going to work in the mac version :)
oh and the preview button might go somewhere else, not sure yet.
Post by fused » Thu Aug 20, 2009 10:33 pm
just made the thing a bit faster, more stable and more reliable :)
Post by zeitmeister » Thu Aug 20, 2009 10:37 pm
Very cool!
There's a discussion about Indigo.app instances on Mac OS here:
http://www.indigorenderer.com/forum/vie ... f=5&t=6609
Will we still be able to convert C4D materials into these Indigo Custom Materials? I would prefer it, but only if the original material is not going to be fully replaced by the new one.
Having the chance to compare the Indigo Custom Material with the original C4D material directly after conversion will be a great help to understand the parameters of the Indigo material system in general.
For me personally, this is a very urgent point!
Post by fused » Thu Aug 20, 2009 10:48 pm
zeitmeister wrote:Very cool!
yeah, saw that. theres a very simple solution to that problem 8)
i better not say it :lol:
zeitmeister wrote:Will we still be able to convert C4D materials into these Indigo Custom Materials?
Sure! It will also happen automatically on export if you dont do that manually.
zeitmeister wrote:I would prefer it, but only if the original material is not going to be fully replaced by the new one.
Won't. C4D material will remain. the material links in texture tags will be replaced.
zeitmeister wrote:Having the chance to compare the Indigo Custom Material with the original C4D material directly after conversion will be a great help to understand the parameters of the Indigo material system in general.
Hehe. Conversion will be relatively rough :)
Post by zeitmeister » Thu Aug 20, 2009 11:01 pm
Wonderful! Once more the master of Awesomeness... :mrgreen:
Post by fused » Thu Aug 20, 2009 11:25 pm
that stuff is still to do :)
Post by fused » Sun Aug 23, 2009 12:13 pm
here are two tests of the material conversion. only c4d materials used which were converted during export :)
they demonstrate abou anything thats supported by the conversion - albedo bump, displacment, exponent, emission maps. phong mat, diffuse mat, oren nayar, specular, glossy transparent.
Post by fused » Sun Aug 23, 2009 12:27 pm
heres another test. stromberg sent me a scene with c4d materials to test.
i think the conversion is decent :)
Post by OnoSendai » Sun Aug 23, 2009 12:57 pm
sweet, nice work!
Post by fused » Sun Aug 23, 2009 10:32 pm
alpha will be converted, too!
iacx
Post by iacx » Mon Aug 24, 2009 12:39 am
This is a marvelous thing...! :D
Post by fused » Mon Aug 24, 2009 10:39 pm
I found a nice way to launch Indigo from c4d. if everything works out nicely Cindigo 2.2 will support launching multiple indigo instances on OSX :)
Post by zeitmeister » Tue Aug 25, 2009 3:01 am
Yes-Yo!
Post by pixie » Tue Aug 25, 2009 12:46 pm
This i a simple test done using the amazing plugin SurfaceSPREAD.
I've first used as is, and it was good, but after I aimed higher and used diffuse transmitter, and just copied the channel over indigos own material.
Indigo with a bit tonemapping and the same render time.
Cinema IR3
Stromberg
Post by Stromberg » Tue Aug 25, 2009 12:51 pm
Indigo version looks sweet :)
Did you buy that plugin or do you use the demo?
