Using render foreground alpha in skindigo
Re: Using render foreground alpha in skindigo
Post by neo0. » Thu Jul 30, 2009 5:21 pm
Really? Hmm, I never knew that.. If only for the purpose of furthering user choice, it would be good if indigo supported a few image formats. BMP, GIF, TGA, etc.
Post by suvakas » Thu Jul 30, 2009 6:28 pm
Cheesestraws wrote:I guess the problem here is the distinction between a feature of the renderer and a feature of the exporter, from what I can tell this is a feature of skindigo that creates an alpha mask for masking out the environment in post. As Indigo doesn't support rendering the background as transparent it is the only way to do it.
Rendering to alpha like it is now is Indigo's feature and not exporter specific.
Post by Borgleader » Thu Jul 30, 2009 10:27 pm
Wow I did not know that. Thanks suvakas :) So how do you "turn it on" add an <alpharender> tag?
Post by suvakas » Thu Jul 30, 2009 10:52 pm
<render_foreground_alpha>true</render_foreground_alpha>
Godzilla
Post by Godzilla » Fri Jul 31, 2009 1:18 am
They really need to incorporate all of these coding features into the GUI.. so you don't need to manually edit the .igs file in a text editor. :(
Post by suvakas » Fri Jul 31, 2009 1:28 am
Those "coding features" are (at least should be) available via your exporter UI.
Post by Whaat » Fri Jul 31, 2009 2:18 am
Godzilla wrote:They really need to incorporate all of these coding features into the GUI.. so you don't need to manually edit the .igs file in a text editor. :(
I'm pretty sure you can render alpha from the Blendigo UI.
Post by Borgleader » Fri Jul 31, 2009 5:22 am
I've never noticed the option before...I'll have to check.
