Indigo 2.0.11
Indigo 2.0.11
Post by OnoSendai » Thu Jul 23, 2009 5:57 pm
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_2.0.11_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_2.0.11_Setup.exe
Linux 32-bit:
indigo_v2.0.11.tar.gz
Linux 64-bit:
indigo_x64_v2.0.11.tar.gz
Changelog:
2.0.11
* Fixed packing of IGMs
* Populating Image save dialogue with scene filename as default filename.
* Populating Pack IGS and Pack IGM save dialogues with default filenames.
* Fixed Aperture diffraction bluriness issue. (See the thread at http://www.indigorenderer.com/forum/vie ... f=7&t=6409 )
Now that aperture diffraction is fixed, everyone should use it on all their renders - because Indigo aperture diffraction is a reasonably accurate simulation of a real and inescapable phenomenon.
WytRaven
Re: Indigo 2.0.11
Post by WytRaven » Thu Jul 23, 2009 8:00 pm
Yay! Now if only I could use it... :(
Re: Indigo 2.0.11
Post by Zom-B » Thu Jul 23, 2009 8:10 pm
Hey Ono, here you got a "Crash & Burn" scene file!
test.zip
(372.13 KiB) Downloaded 373 times
Jambert
Re: Indigo 2.0.11
Post by Jambert » Thu Jul 23, 2009 11:23 pm
Is it possible to enable/desable automatic update when I test light...
edit: Sorry I just found how to do it
Re: Indigo 2.0.11
Post by Zom-B » Fri Jul 24, 2009 1:24 am
here a quick test:
Re: Indigo 2.0.11
Post by suvakas » Fri Jul 24, 2009 1:54 am
ZomB wrote:here a quick test:
Did you made the scene like that. Is it expected behaviour? =)
Re: Indigo 2.0.11
Post by Zom-B » Fri Jul 24, 2009 2:21 am
oh yes it is... just a field with 100 emitting spheres and a cam with small aperture size + obstacle map!
At the moment I only have problems to get this working with image based lightning... like envMaps (and envMap reflections!) :/
Ono, before I continue testing... does this work with image based light anyway??
Re: Indigo 2.0.11
Post by pixie » Fri Jul 24, 2009 11:50 am
A perfectly fine scene render useless by 2.0.10 :(
Also the same problem on 2.0.11
bug.zip
(166.16 KiB) Downloaded 392 times
Re: Indigo 2.0.11
Post by OnoSendai » Fri Jul 24, 2009 1:23 pm
ZomB wrote:Hey Ono, here you got a "Crash & Burn" scene file!
Zom-B: You're an Indigo-crashing machine, aren't you :)
The bug was with the one-component obstacle map, have fixed for next release.
Re: Indigo 2.0.11
Post by OnoSendai » Fri Jul 24, 2009 1:27 pm
Pixie:
I investigated the bug you are referring to. It's a self-intersection issue.
I tested out a possible fix, to make the intersection a little more robust. Unfortunately, it slows down rendering speed by something like 3%-10%. So I'm not sure if it's a good idea to include, seeing as most scenes render fine.
I think you are seeing issues because your model is quite large - larger than it should be (if one unit = one metre) , and not near the origin of the scene.
I'm still investigating this issue, so any feedback or thoughts are welcome.
Re: Indigo 2.0.11
Post by OnoSendai » Fri Jul 24, 2009 1:28 pm
WytRaven wrote:Yay! Now if only I could use it... :(
Ah.. sadly, We'll have to wait till Monday to do a Mac build.
WytRaven
Re: Indigo 2.0.11
Post by WytRaven » Fri Jul 24, 2009 1:40 pm
OnoSendai wrote:Ah.. sadly, We'll have to wait till Monday to do a Mac build.
I will try to survive till then. Would I be able to resume my current hi-res rings render from the current 2.0.10 igi (@ about 8.6K spp) with the new build and edit the igs to enable aperture diffraction or will that likely cause problems?
Re: Indigo 2.0.11
Post by OnoSendai » Fri Jul 24, 2009 1:53 pm
The IGI will definitely be compatible. Editing the camera aperture after the render is an interesting question. Any new samples will be bogus, i.e. effectively rendered using a different scene.
You can certainly enable aperture diffraction. Changing the aperture size etc.. may or may not work :)
I think if you resume the render, then hit stop immediately, then you can mess around with various aperture sizes and shapes.
WytRaven
Re: Indigo 2.0.11
Post by WytRaven » Fri Jul 24, 2009 2:05 pm
ok well I'll leave the current render going and then maybe play around on a backup once the new build is available and see what happens ;)
Re: Indigo 2.0.11
Post by OnoSendai » Fri Jul 24, 2009 2:21 pm
Added Linux builds.
