Indigo 2.0.10
Re: Indigo 2.0.10
Post by OnoSendai » Fri Jul 17, 2009 12:56 pm
ZomB wrote:Seems like the testscenes "€.igs" and "unicode_€_test.igs" cause an error... so the unicode support seems not to work!?
"€.igs" is only supposed to be included from other files, so won't work opening directly.
"unicode_€_test.igs" should work however.
If it doesn't, can you paste the error message that it gives?
Thanks.
Re: Indigo 2.0.10
Post by OnoSendai » Fri Jul 17, 2009 1:12 pm
pixie wrote:I'm getting some mesh troubles, first I though it to be bump related but after taking it away the persist...
Hi Pixie,
can you simplify the scene as much as possible, while still maintaining the bug, then send it to me?
You can email it if < 3MB or use box.net.
Re: Indigo 2.0.10
Post by pixie » Fri Jul 17, 2009 6:58 pm
Hi Pixie,
Since I don't know your mail I've sent you a pm.
PS- indigorender site doesn't acknowledge the pigs format which is in itself a scandal!
cpfresh
Re: Indigo 2.0.10
Post by cpfresh » Fri Jul 17, 2009 7:49 pm
pixie wrote:PS- indigorender site doesn't acknowledge the pigs format which is in itself a scandal!
ROFL !
Re: Indigo 2.0.10
Post by Zom-B » Sat Jul 18, 2009 11:38 pm
Just having some issues with Subdivison with this error message:
Error: ObjectExcep: Exception while building tree: BVH Build failure, too many triangles in leaf.
Here is the interesting part of the log:
Subdividing and displacing mesh 'test-19.igmesh', (max num subdivisions = 4) ...
	Doing subdivision level 0...
		num triangles subdivided: 90976
		num triangles unchanged: 10192
		resulting num vertices: 190889
		resulting num triangles: 376256
		Done.
	Doing subdivision level 1...
		num triangles subdivided: 318445
		num triangles unchanged: 55651
		resulting num vertices: 675196
		resulting num triangles: 1333092
		Done.
	Doing subdivision level 2...
		num triangles subdivided: 953114
		num triangles unchanged: 376317
		resulting num vertices: 2120528
		resulting num triangles: 4194177
		Done.
	Doing subdivision level 3...
		num triangles subdivided: 1208943
		num triangles unchanged: 2979830
		resulting num vertices: 3973775
		resulting num triangles: 7822932
		Done.
	Done.
Building Mesh 'test-1.igmesh'...
	4 vertices (96 B)
	2 triangles (56 B)
	Loading kd-tree from cache...
	intersect_tris mem usage: 96 B
	calcing root AABB.
	AABB: (-0.521207, -0.359821, -0.000000), (0.521207, 0.359822, -0.000000)
	max tree depth: 62
	total nodes used: 2 (16 B)
	total leafgeom size: 2 (8 B)
	Total tree mem usage: 96 B
Done Building Mesh 'test-1.igmesh'. (Time taken: 0.00071 s)
Building Mesh 'test-19.igmesh'...
	3973775 vertices (90.952 MB)
	7815602 triangles (208.699 MB)
	BVH::build()
	Calcing root AABB.
		Done.
		Root AABB min: (-0.065672,-0.021514,-0.152898,1.000000)
		Root AABB max: (-0.003386,0.024102,0.143670,1.000000)
	Sorting...
		Done (6.44867 s).
Stopped.
Maximum RAM usage during Scene Build was @ 1.2 GB... I have 4GB on vista 64bit
Re: Indigo 2.0.10
Post by Zom-B » Sat Jul 18, 2009 11:57 pm
Ok, it seems this bug also apears with SD @ 2 !?!
I attached the scene file...
bvh_bug.zip
the scene file...
(2.15 MiB) Downloaded 242 times
Re: Indigo 2.0.10
Post by Zom-B » Wed Jul 22, 2009 1:37 am
Somehow it seems that the "below normal" priority switch in Indigo doesn't work.
Indigo allways slows down my system, just like in "normal" mode, so I have to change it in the taskmanager by hand :/
Vista 64bit
Re: Indigo 2.0.10
Post by pixie » Wed Jul 22, 2009 1:40 am
ZomB wrote:Somehow it seems that the "below normal" priority switch in Indigo doesn't work.
Vista 64bit
Same here
7 64bit
cpfresh
Re: Indigo 2.0.10
Post by cpfresh » Wed Jul 22, 2009 2:50 am
maybe an exporter issue? ... works with skindigo.
7/32 bit
Re: Indigo 2.0.10
Post by pixie » Wed Jul 22, 2009 2:51 am
7/32 bit
you have 32 bit...
Re: Indigo 2.0.10
Post by Zom-B » Wed Jul 22, 2009 3:09 am
its not relarted to the exporter since you have the dropdown menu for Thread Priority and can set it by hand...
cpfresh
Re: Indigo 2.0.10
Post by cpfresh » Wed Jul 22, 2009 3:20 am
oh i see, i see. i immediately thought of 'on launch' not via toggle in indigo. sorry. i just tried mine as well and don't see the priority change in the task manager ...
Re: Indigo 2.0.10
Post by suvakas » Wed Jul 22, 2009 3:30 am
UI selection changes the priority of the rendering threads and not the main indigo.exe. Under Task manager it still shows "normal", but the threads doing rendering should be in "below normal" mode.
Re: Indigo 2.0.10
Post by pixie » Wed Jul 22, 2009 3:37 am
suvakas wrote:UI selection changes the priority of the rendering threads and not the main indigo.exe. Under Task manager it still shows "normal", but the threads doing rendering should be in "below normal" mode.
It might be, but it's still slow as hell! :p
Users browsing this forum: DotBot [Bot] and 3 guests
