PLEASE HELP!!!!
- Borgleader
Re: PLEASE HELP!!!!
Wrong, I said look for the name inside the file, not the name of the file. If you look carefully you'll notice that inside the "Ghot_Glass.igm" file there is a "Thin Glass" material (of type blend) that is using two sub materials called "SP_Thin Glass_SP" (type phong) and "NULL_Thing Glass_NULL" (type null).
Of course you want the resulting material, which is the one of type blend, so you should name your blender material "Thin Glass".
Do you follow the logic?
Re: PLEASE HELP!!!!
Whenever i tried to get into the file ti wouldn't let me because it said it needed a program to run it.
- Borgleader
Re: PLEASE HELP!!!!
Notepad will (I'm assuming you're working on windows).3D Geek wrote:Whenever i tried to get into the file ti wouldn't let me because it said it needed a program to run it.
EDIT: notepad will also read .igs files (the scene files upon export). I do however suggest notepad++ (google it) because the bigger the file gets the higher your chances of notepad crashing. For material files (.igm) its no problem but for scene files (.igs) it most likely will.
Re: PLEASE HELP!!!!
ooooooooooooh, ok thanks, now i see it!
- Borgleader
Re: PLEASE HELP!!!!
OK, i know that this thread was supposed to be dead, but now im having another problem with a mterial from the database.Whenever i apply the frosted galss material from the database on to something, it turnd out like this. Whenever i try to make my own glass like materials it does the same. What am i doing wrong?
- 3.jpg (236.04 KiB) Viewed 3790 times
- PureSpider
Re: PLEASE HELP!!!!
well i tried flipping the normals and i got the same result
- Borgleader
Re: PLEASE HELP!!!!
Does it have thickness? If it doesnt its normal for it to go black.
Re: PLEASE HELP!!!!
o, ok thanks i will try that
Re: PLEASE HELP!!!!
ok i tried thickening up a modle and it did the same thing, but this time i used the emerald material from the database. Any other suggestions?
Re: PLEASE HELP!!!!
How large is the model? can we see a screenshot from the viewport?
- PureSpider
Re: PLEASE HELP!!!!
Be sure all normals are pointing outwards after giving it some volume!
Re: PLEASE HELP!!!!
ok well heres the scene, ther is a sphere behind the wall with the emerald material applied to it.
- ITeast.jpg (245.29 KiB) Viewed 3729 times
