- pixie
Just two very happy Buddhas...
- Alluminium
- happybuddhaAl.png (76.96 KiB) Viewed 3701 times
- Gold
- happy buddha.png (54.89 KiB) Viewed 3703 times
- pixie
An experiment, post processed with photoshop, mainly crop and background
- Top view
- isometric.jpg (181.14 KiB) Viewed 3631 times
- PureSpider
Nice! How far away is your camera from the model? I'm guessing those windows are emitters and not allowing actual daylight? Otherwise do tell how?pixie wrote:An experiment, post processed with photoshop, mainly crop and background
- pixie
dmn wrote:Nice! How far away is your camera from the model? I'm guessing those windows are emitters and not allowing actual daylight? Otherwise do tell how?
They're all exit portals, as for the camera it was about 900m and had 1º FOV
- Polinalkrimizei
Cool experiment pixie! First I thought it was a photoshop trick.Who thought indigo could do ortographic view
Crazy idea and looking very neat!
I quite don't understand; don't exit portals exige the camera to be within the sealed volume ? I don't get the trick but I like the resultpixie wrote:They're all exit portals, as for the camera it was about 900m and had 1º FOVdmn wrote:Nice! How far away is your camera from the model? I'm guessing those windows are emitters and not allowing actual daylight? Otherwise do tell how?
- PureSpider
That's what I thought o.OCTZn wrote:I quite don't understand; don't exit portals exige the camera to be within the sealed volume ? I don't get the trick but I like the resultpixie wrote:They're all exit portals, as for the camera it was about 900m and had 1º FOVdmn wrote:Nice! How far away is your camera from the model? I'm guessing those windows are emitters and not allowing actual daylight? Otherwise do tell how?
Not at all. Exit portal just limits the rays to the portal area. It basically acts like an evironment colored emitter.CTZn wrote: I quite don't understand; don't exit portals exige the camera to be within the sealed volume ? I don't get the trick but I like the result
[edit]
Added image to illustrate the portal behaviour.
- portal.jpg (30.85 KiB) Viewed 4020 times
Teapots !!!
Tested 2 HDRI maps. A bit noisy cause both rendered only about 20 minutes.
- HDRI_Teapots.jpg (84.54 KiB) Viewed 3275 times
- PureSpider
Stunning!
Are those HDR maps hand-made or did you dl them from somewhere?
