Blendigo not installing correctly?
13 posts • Page 1 of 1
Godzilla
Post by Godzilla » Wed Jul 15, 2009 12:51 pm
Blendigo randomly pooped out on me and stopped auto-running (It said it could not locate Indigo.exe?), so I un-installed it, reinstalled it, and nothing changed. I then Uninstalled all Indigo-related things on my computer, reinstalled them, and it still didn't work. This is the error I get when I try to switch to the 'Render with Indigo' Script.
Polinalkrimizei
Re: Blender not installing correctly?
Post by Polinalkrimizei » Wed Jul 15, 2009 4:10 pm
Hey Godzilla, try to manually install indigo. You don't just need the blendigo script, but also two (? I am at work so I can't check it quickly) folders containing whatever but also the missing image. You'll find them somewhere in the \appdata\blender foundation\.blender\scripts folder.
Godzilla
Post by Godzilla » Wed Jul 15, 2009 4:23 pm
Polinalkrimizei wrote:Hey Godzilla, try to manually install indigo. You don't just need the blendigo script, but also two (? I am at work so I can't check it quickly) folders containing whatever but also the missing image. You'll find them somewhere in the \appdata\blender foundation\.blender\scripts folder.
What do you mean manually install indigo?...
And I know I don't just need the blendigo script, but everything seems to be there... :?
And shouldnt blendigo be installed in the Program Files path of Indigo, not the Users\(My name)\appdata\roaming path?...
Godzilla
Re: Blendigo not installing correctly?
Post by Godzilla » Thu Jul 16, 2009 12:22 am
Just notced the titile said 'Blender not installing correctly'
Fixed. :oops:
Polinalkrimizei
Post by Polinalkrimizei » Thu Jul 16, 2009 12:30 am
I meant manually install Blendigo of course. :oops:
And I know my post doesn't make too much sense, but it worked in my case. I had the same error and noticed that blendigo installed itself in the \appdata...\ directory, not in program files.
I just copied it manually to the blender folder in the program files and now everything is fine...
Post by Borgleader » Thu Jul 16, 2009 9:22 am
If you upgraded to the latest version of blender i do believe it requires Python 2.6?
dmn
Post by dmn » Thu Jul 16, 2009 11:49 am
If you're like me and you tend to click through install programs without looking at anything, you may have missed the part where it asks you for the blendigo install directory, which for some reason thinks blender is in documents and settings instead of program files... :D no need for manual install.
Godzilla
Post by Godzilla » Thu Jul 16, 2009 2:31 pm
dmn wrote:If you're like me and you tend to click through install programs without looking at anything, you may have missed the part where it asks you for the blendigo install directory, which for some reason thinks blender is in documents and settings instead of program files... :D no need for manual install.
Post by OnoSendai » Thu Jul 16, 2009 2:33 pm
We have an installer update that will be released this week some time.
That may fix some problems people are seeing.
Godzilla
Post by Godzilla » Fri Jul 17, 2009 9:45 am
Day 2 without Blender or Indigo..
My mouth is dry.. My eyes are sore... I can no longer remember what color the blender logo is.. and that scares me. Was it blue? red? perhaps I will never know.
Godzilla
Post by Godzilla » Fri Jul 17, 2009 10:11 am
Ok, well I have the Blender issue sorted out (Finally), but the Blendigo install issue still persists.
I get this error.
My Blender.exe file is located in C:\Program Files\Blender...
Although this isn't the default blender directory, It should still be able to locate it, shouldn't it?..
Benn, in the next release of Blendigo, could you please make it so that you can specify the location of the Blender Scripts folder at the Indigo folder manually? It would save a lot of people a lot of aggravation, even if it took the extra 10 seconds to specify the directories.
Post by OnoSendai » Fri Jul 17, 2009 12:20 pm
The next installer will give the option to set the path yourself.
Godzilla
Post by Godzilla » Fri Jul 17, 2009 12:27 pm
OnoSendai wrote:The next installer will give the option to set the path yourself.
Thanks Ono! :o
