Iceberg
Re: Iceberg
@stur: The outer faces of your water cube look all wonky from the subdiv, what sorted it out for me was use the edge-split modifier on the water cube and gave it an extra two edge loops fairly close to all the faces just to add a bit more weight to those edges. I also think curve threshold was -1.
Heres my last render which I piddled a bit with in photoshop. I also think I missed something when unwrapping the iceberg mesh for for UV because that repeating pattern shouldn't be there.
- iceberg_post.jpg (125.23 KiB) Viewed 12993 times
Re: Iceberg
@Polinalkrimizei : thx m8
It gives me a bit of courage to try harder. Not this evening unfortunately as I was out, but I'll go on. Concerning the SSS code, Ono wrote he'll have a look. At least concerning the weird pictures I got when my icerberg had SSS too.
@neepneep: I don't understand how curve threshold exactly works, so I put it to 0 and used pixel threshold instead, I set it to 1.
My water cube is now a water cylinder. Just another random test to get rid of these dark areas but with no success.
Your iceberg is better now, white
Indeed the texture looks a bit tiled, but your water is very clean.
Tip : if you want to get cool caustics, you should set the Max Change value to 0.003 and use a sun for lighting (credit to CoolColJ for this tip).
- Polinalkrimizei
Re: Iceberg
Stur, perhaps you could cut some loops into your iceberg mesh, so your isl-displacement looks more evenly distributed?
Just guessing don't really know much about it
but could we see a wire render?
Re: Iceberg
Well, in fact it was on purpose to have an un-even distribution of the displacement. I draw a "weightmap" directly in Blender, and used it in my isl to modulate the fbm() function (which generates fractal noise).
Here are a few shots of the scene however.
- Wireframe
- icerberg_wireframe.jpg (171.9 KiB) Viewed 12918 times
- Scene overview
- scene_overview.jpg (90.51 KiB) Viewed 12919 times
Re: Iceberg
Ok, here is the product of the night.
I finally got rid of the black triangles in the water. I made my mesh way more deeper.
I also modified a bit the iceberg displacement but it's still not convincing.
The water is getting better, but there is some strange noise. I think I've put too much SSS, or the image is still not converged. What do you, guys, think about the cause of the white noise in the water ?
Thx.
Thx.
- The scene.
- im1246482558.png (659.46 KiB) Viewed 12869 times
- The iceberg alone.
- im1246482192.png (785.76 KiB) Viewed 12873 times
Re: Iceberg
If the water material has some sss one should get volumetric caustics, no ? So yes that might need more convergence...What do you, guys, think about the cause of the white noise in the water ?
Nice and fun ISL use !
- Polinalkrimizei
Re: Iceberg
Wow Stur you are really getting there...
I personally like the iceberg better now. Some more nights and your image is gonna look like the famous photo!
Re: Iceberg
Uuuuh, it looks cold
And perfect!
Re: Iceberg
Thx guys
Personnaly I wasn't satisfied with the iceberg. So I decided to model another. I'm quite happy with the emerged part of the new one, but I don't like the other. So I stopped the render and I'll try to improve the mesh later.
- Another iceberg. And camera tonemapping instead of reinhard.
- im1246657404.png (753.93 KiB) Viewed 12711 times
Re: Iceberg
Ok, I think I'm done.
I cut the iceberg in two meshes : the emerged one, unsmoothed with a displacement map, and the underwater one, smoothed with a simple fbm() displacement function.
At first I tried to put SSS on the underwater part, but it seems impossible to converge. I even tried to render a tiny picture at 39 000 SPP ! But the icerberg was still far from converged, so I abandon SSS.
Unless someone has a good idea to improve the picture, or some good critics, I'll consider this scene finished and will render a bigger version.
- im1246828115.png (631.14 KiB) Viewed 12626 times
Re: Iceberg
You could wait for 2.0.10, Ono seems to work on SSS:Stur wrote:Unless someone has a good idea to improve the picture, or some good critics, I'll consider this scene finished and will render a bigger version.
http://www.indigorenderer.com/forum/vie ... 728#p76728
Anyway, I like your Iceberg the way it is
- zeitmeister
Re: Iceberg
Damn, this result is amazing realistic, Stur!
Re: Iceberg
+1zeitmeister wrote:Damn, this result is amazing realistic, Stur!
This is really starting to come together now. The top of that iceberg is pretty much perfect...and that's all I can comment on as I don't think I've ever seen what the rest looks like
Re: Iceberg
The fun part is that it is absolutely accidental ! I spent an hour drawing a displacement map in PS, using photos of real icebergs, but when I rendered, I forgot to change the map in Blendigo. So the map really used was just a weightmap drawn by hand in Blender for a previous ISL test. When I realized that, I did another render with the good map, but the result was far from good, so I went back to the accidental wrong mapWytRaven wrote: The top of that iceberg is pretty much perfect...
Sometimes I'm just lucky.
Thx for the comments guys
@ZomB : yeah I saw this post and I'll definitely give a try with 2.0.10.
Re: Iceberg
The icerberg rendered with 2.0.10 (approx 6K spp). The water suddenly looks dark.
A also tried a hires version with 1.1.14, but stopped after 80 hours. Even with way more spp, the picture seemed impossible to converge, I was not able to get as good caustics as I did at 800x600.
- 2.0.10
- im1247918731.png (615.37 KiB) Viewed 12470 times
