by Whaat » Fri Jun 26, 2009 3:01 am
thiloo wrote:hi Whaat,
get same errors!
renaming the files make no difference.
Also can confirm that I do not get these errors using SkIndigo 2.0.4.
Thanks thiloo.
Could I please get you and everyone else that is having problems to post their Internet Explorer version and OS?
Also, are the errors only occuring when opening the Material Editor? What about when you open the Render Settings dialog? Any errors?
thiloo
by thiloo » Fri Jun 26, 2009 3:49 am
Vista 64 and IE7
No errors, when opening the Render Settings dialog.
Error occurs:
- when opening the Material Editor
- when slecting new material, while the Material Editor is open
remus
by remus » Fri Jun 26, 2009 3:56 am
Upgrading to IE8 seems to have fixed it for me.
- 3D Software: SketchUp
by Pibuz » Fri Jun 26, 2009 4:25 am
Thanks Whaat and Ono for the release: here is a test with the sun/sky splitting.
VEEEERY COOOOOL!
Cheers!
by Pibuz » Fri Jun 26, 2009 4:44 am
Hey Whaat: upgrading to IE8 fixed all the problems here too!
I guess we found the bug
by Whaat » Fri Jun 26, 2009 8:43 am
thiloo wrote:Vista 64 and IE7
Error occurs:
Can you try upgrading to IE8?
That may fix the problem.
by Whaat » Fri Jun 26, 2009 4:41 pm
I think I have fixed the Material Editor bug that has been reported. If you are having these sorts of problems, please remove your current SkIndigo installation and download again from the links in the first post. This version should work for users who do not want to upgrade to IE8.
Can someone confirm that this verison works on Mac??
by neo0. » Sat Jun 27, 2009 1:32 pm
I click on the render button and nothing happens. It says it's collecting something at the bottom, but indigo never loads up.
cpfresh
by cpfresh » Sat Jun 27, 2009 1:43 pm
open the ruby console and check the output ... there may be some useful information.
by Whaat » Sat Jun 27, 2009 2:16 pm
cpfresh wrote:open the ruby console and check the output ... there may be some useful information.
Yes,
please open the ruby console and let me know of any messages.
Also, make sure you deleted all your old SkIndigo versions prior to installing the latest 2.0.8.
by neo0. » Sat Jun 27, 2009 3:39 pm
Ruby console output
Renderer/default-meshes.igs>
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo.rb:427:in `initialize'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo.rb:427:in `new'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo.rb:427:in `export'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo.rb:7336
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo.rb:7336:in `call'
- fllaaahhh.jpg (312.07 KiB) Viewed 3100 times
cpfresh
by cpfresh » Sat Jun 27, 2009 3:42 pm
that's the full log?
by Whaat » Sat Jun 27, 2009 4:10 pm
I need the full Ruby log, neo.
by neo0. » Sat Jun 27, 2009 5:26 pm
Whoops
Error: #<Errno::ENOENT: No such file or directory - C:\Users\Eric\AppData\Roaming/Indigo Renderer/default-meshes.igs>
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo - Copy.rb:7336
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo - Copy.rb:7336:in `call'.
There we go.
by Whaat » Sun Jun 28, 2009 2:08 pm
neo0. wrote:Whoops
There we go.
Neo,
It looks like you have two copies of skindigo in your plugins folder (evidenced in the error message by 'skindigo - Copy.rb')
I suppose this isn't the cause of the error because your first post does not indicate that you had two copies at the time you got the error message.
Can you check if you have the following path:
