Cindigo 2.0.6 - beta
Re: Cindigo 2.0.6 - beta
Post by zeitmeister » Thu Jun 18, 2009 12:34 am
Yo!
Your beta already worked fine... forgot to tell you that, shame on me! :oops:
Post by zeitmeister » Thu Jun 18, 2009 1:09 am
Erm...
how do I export with motionblur?
Made an animation; frame 0 to 10. Now I want to render frame 6 with motionblur... how do I do that?
Do I have to make changes to the camera settings; a higher "Belichtungsdauer" or a higher F-Stop?
What do I have to click exactly in the Cindigo render output window?
Thanks in advance!
Post by fused » Thu Jun 18, 2009 1:29 am
just use c4ds motion blur tag :)
with an exposure of 1 second and 25 frames per second 25 frames will be taken into consieration for the motion blur. the standard exposure without a camera tag is 0.05 seconds.
and please keep in mind, that only keyframe based motion blur can be evaluated at the moment...
Post by zeitmeister » Thu Jun 18, 2009 1:52 am
Got it, thank you very much!
I've got several ideas in mind... let's see. :mrgreen:
It would be great if you get access to animate-along-spline animations. I use this the most. for camera flights etc... XPresso-based animation support would be a killer, too.
Just think of all the steadycam- or handcam-movement solutions for C4D around there...
Post by fused » Thu Jun 18, 2009 2:24 am
yeah.... for the moment youll have to record all the keyframes. should work with xpresso, along spline, ect....
will come at some point tho. its really tricky...
Post by zeitmeister » Thu Jun 18, 2009 4:48 am
I knew! :o
Maybe I discovered a little issue: blackbody material emitters come out very strong; the light normalisation doesn't seem to work proper (tried to set the flux value to 0.001).
It comes up only in a specific scene of me and I can't reproduce it for the moment...
Could you risk a quick look or should I clean my scene for you?
Post by fused » Thu Jun 18, 2009 5:46 am
sure, but thats probably an indigo issue. but i could tell you for sure if you send me the scene :)
a.manca
Post by a.manca » Fri Jun 19, 2009 12:39 am
Thanks fusedd! :D :D :D :D :D :D :D :D
a.manca
Post by a.manca » Fri Jun 19, 2009 1:04 am
Another question: How does the preview of Cindigo for mac?
Post by fused » Fri Jun 19, 2009 1:24 am
the material previews? they are currently disabled for the mac version, but will be enabled in the next version.
i just forgot to enable them again. sorry :)
a.manca
Post by a.manca » Fri Jun 19, 2009 1:58 am
fused wrote:the material previews? they are currently disabled for the mac version, but will be enabled in the next version.
Ok.How does the bump?
Post by fused » Fri Jun 19, 2009 3:02 am
Insert a bump texture in bump channel of the material linked in the material helper.
a.manca
Post by a.manca » Fri Jun 19, 2009 4:43 am
Just the normal operation!
a.manca
Post by a.manca » Sat Jun 20, 2009 8:56 pm
I can't export lights!!!I created an area light. I applied the tag to light. I exported the scene and seems that there are no lights because I do not see the shadows!
a.manca
Post by a.manca » Sat Jun 20, 2009 9:02 pm
Sorry!No problem...
Users browsing this forum: Ahrefs [Bot] and 24 guests
