[ISL][workshop] Indigo Shading Language
Re: [ISL][workshop] Indigo Shading Language
wow, thats pretty awesome!
- Borgleader
That is pretty cool, with a little tweaking you could easily do bricks
Thx guys.
Yes Borgleader, I think I could do bricks as it is easier than stones with beveled edges.
Here is another try, I used my previous script but changed some values.
- Another attempt :
Square stones, mortar thiner, other colors and a bit heavier displacement. - im1245326088.png (815.57 KiB) Viewed 3754 times
Awesome contibution Stur !
And darn usefull, I'm saving it to disk right now, thank you too
Really ? I'm honored ^^
I'm looking forward to see what you'll draw with my texture.
ISL is fun after all
I will continue to experiment. (I also encountered a few crashes)
Here is another experiment with the script. I extruded the plane, and bad things happen at angles. I tried a few unwrapping methods, I tied to place the seams at other places, no matter what I do, the result is the same
I've also noticed a strange behavior : getStones() substract a noise map to the brick map. I multiply the noise map by a value to make more or less strong. What is strange, is that if i put a too small values (to get a thiner noise map), suddenly there is no displacement at all.
def myNoise(real conc, real f) real:
fbm(getTexCoords(0) * conc, 10) + 1.0
) / 2.0
) * f
# getStones() : blends the brick wall with the noise map to draw a stones like map
def getStones() real:
max(
min(
getBricks(0.1, 0.05, 0.002, 0.002)
* 20.0
, 1.0
- myNoise(50.0, 0.5) # if i reduce this value, 0.5 to 0.2 for example, then there is no displacement
, 0.0
- Same script, other parameters.
- im1245483964.png (690.36 KiB) Viewed 3643 times
This is the displacement_error_threshold, set it to a negative value to disable it, modify the igs by hand if it is hardcoded in the exporter. It's supposed to do just that, not subdividing details below a given height.What is strange, is that if i put a too small values (to get a thiner noise map), suddenly there is no displacement at all.
For the border thing you want to disable subdivision smoothing like so:
<subdivision_smoothing>false</subdivision_smoothing>And yes I have an obvious idea in mind, somehow I'm surprised I was not beaten at it yet but I'll give it a try. This stuff is starting to look usefull.
Users browsing this forum: No registered users and 69 guests
