Cindigo 2.0.6 - beta
Re: Cindigo 2.0.6 - beta
Post by fused » Wed Jun 10, 2009 10:46 am
There was a bug in the motion blur export. only the first and the last keyframe were exported correctly. all other frames were exported from the beginning of the animation. will upload new builds tomorrow.
Post by fused » Wed Jun 10, 2009 11:16 am
uploaded them now :)
some testrendering:
Post by zeitmeister » Wed Jun 10, 2009 5:58 pm
DAMN-THIS-LOOKS-GREAT!
I'll finish up the test scene with the light-layer-issue this morning... :-)
Post by fused » Thu Jun 11, 2009 7:06 am
:D
Post by OnoSendai » Thu Jun 11, 2009 2:01 pm
It's a rotating wheel? Cool :)
Post by zeitmeister » Fri Jun 12, 2009 7:44 pm
This.Is.So.Cool!
Post by fused » Tue Jun 16, 2009 8:36 am
glad you like it!
im working on getting the indigo instance object exported as instances. im close:
Post by fused » Wed Jun 17, 2009 12:11 pm
im done. it works amazingly well:
real instances with the indigo instance object :)
seems quite bug free, also.
Post by zeitmeister » Wed Jun 17, 2009 7:56 pm
Wow!
Post by fused » Wed Jun 17, 2009 9:44 pm
more instancing tests, plane from colacola.se.
no idea how many instances (i have not implemented an instance counter yet :) ), but i guess somewhere around 15k?
edit: export time was about 2.6 seconds, plane has ~80k polygons
planes in circles give nice patterns :)
Post by zeitmeister » Wed Jun 17, 2009 9:53 pm
fused, what do I see here; sorry for missing that point.
Are they the "ordinary" Cindigo instances, apart from your C4D instance plugin? Or are they the same?
The instances aren't being converted to meshes during export to Indigo, they are real Indigo instances, right?
Do you plan to merge the functionality of your C4D instance plugin with the Cindigo instances, or had this happened already?
Post by fused » Wed Jun 17, 2009 10:21 pm
zeitmeister wrote:fused, what do I see here; sorry for missing that point.
no problem :)
zeitmeister wrote:Are they the "ordinary" Cindigo instances, apart from your C4D instance plugin? Or are they the same?
The 'editor instance' plugin was originally a further developed 'indigo instance' for cindigo, but some wanted it as a sperate plugin, so i gave them what they wanted :)
zeitmeister wrote:The instances aren't being converted to meshes during export to Indigo, they are real Indigo instances, right?
Yes. They are not exported as seperate meshes, but as real instances. Also, the instance object is not converted to mesh objects on export (that would normally happen with c4d instances and the editor instance plugin). saves some ram and time.
zeitmeister wrote:Do you plan to merge the functionality of your C4D instance plugin with the Cindigo instances, or had this happened already?
Happened already :)
note that 'editor instance' objects will not be exported as real instances. the suppression of the conversion to meshes on export works only in the 'indigo instance' that comes with cindigo.
a.manca
Post by a.manca » Wed Jun 17, 2009 10:45 pm
When Cindigo 2.0.6 released for mac?
Post by fused » Wed Jun 17, 2009 10:50 pm
a.manca wrote:When Cindigo 2.0.6 released for mac?
oh, yeah... i forgot that. will do that now :)
Post by fused » Wed Jun 17, 2009 11:28 pm
added the 2.0.6 mac build.
