I really love your tests Suvakas
@suvakas: love it! what technique did you use to have all the crevices all yellow. Is the displaced material blended with a yellow material using a blend map similar to the displacement map? Very cool test...
Nice one suv.
- Borgleader
If the cracks were smaller and if the colors were right...this could look like a dried up doughnut. Are you prepared for the challenge?suvakas wrote:I've started to abuse donuts now in my tests instead of teapots.![]()
Just polishing up the displacement implementation for Maxigo and this is one of the tests i did today.
Not but seriously, I am amazed yet again
nice stuff suv !
Films variations:
Films variations:
- lampe_vessie_compo.jpg (148.22 KiB) Viewed 3788 times
Thanks guys !
@CTZn
I love the lamps. The model looks very real. Specially folds around the left corner.
It's actually simpler than that. I used Max procedural map called "Mix" and it allows you to mix 2 textures using a map. I mixed 2 colors - green and yellow. So for Indigo it is just a bitmap texture (Max procedural rendered to a bitmap).Whaat wrote:@suvakas: love it! what technique did you use to have all the crevices all yellow. Is the displaced material blended with a yellow material using a blend map similar to the displacement map? Very cool test...
@CTZn
@CTZn
Yes very nice lamps ! The lamp shade looks very realistic and the model-like as well.
wow, CTZn!
thats a really great lamp!
@suvakas: procedural powa
Thx Camox, much apreciated from you ! The lampshade is a blend (0.587/1) between a diffuse and a diffuse_transmitter, both using the same texture as albedo.
Cheers fused ! Really simple stuff, it's using a cloth sim wich is subdivided further by Indigo.
Link to the final render, along with the pigs:
http://www.indigorenderer.com//forum/vi ... 896#p74896
Care to share that shade material, CTZn?
Please follow the link above Godzilla ! But the texture was baked against the cloth UVs so it will just give a hint; it's a simple fractal noise.
You want an IGM with a plain texture to UV map ?
Didnt even read to the end of the post
lol.
lol.
that render is actually sexual. im slightly aroused. amazing lamp!
I'm still lost on how to put materials from the database into your scene.
