SkIndigo 1.0.9 Official
hi,
im not sure what you mean? when i send it to render i am facing the area i want to render, its odd though that some of the glass is renderd and not other bits?
if you could let me knwo what you mean by faces i would be very grateful, ive only just started using indigo and sketch up..
many thanks
many thanks
oh ok. the easiest way to check your face orientation is by using the 'monochrome' render method in sketchup. there will be two colors displayed a 'front' color and a 'back' color. make sure all of the 'front' faces are pointed outward of the geometric shapes and visible by the camera. hope that helps.
Re: SkIndigo 1.0.9 Official
I have a problem with the installation on mac.
After the initial request of locating the indigo.exe file... I must remember that there is no .exe files on mac... I select the indigo.app as file path and then SU sends me another message:
Error Loading File SkIndigo_1_0_9.rb
Permission denied - /Users/User/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/indigo_1_0_9path.txt
I checked my permissions and they are allright
If I put the .rb file and folder in the plugins of the general library instead the user library I get this message:
can't convert nil into String
So I suspect I'm getting this problem because I'm installing files in the bad folder but there are 3 or 4 folders that SU can call to look for plugins.
Download link nolonger works
http://www.indigorenderer.com/dist/plug ... -1.0.9.zip (or go to the Downloads Page)CoolColJ wrote:Download link nolonger works
Sorry Lander, I missed this post. SkIndigo 1.0.9 does not work on Mac. I am currently working hard to make the next version (2.0.X) fully Mac compatible.Lander wrote:I have a problem with the installation on mac.
