Error using Blendigo 1.1.18 and Indigo 2.0.5/6
5 posts • Page 1 of 1
Doug Armand
Post by Doug Armand » Wed May 20, 2009 12:49 am
Using Indigo 2.0.5/6 x64, Win 7 x64, Blendigo 1.1.18
Export to Indigo using Blendigo 1.1.18 with the default.igs option unselected and get this error message
Indigo GUI loads and pops up that error message.
It seems a .igs file is created with an extra .igs in the filename added as in WaterJug_Desert.igs.igs
Indigo pops up that error message and stops.
If I then cancel that message and use 'Open Scene' I can load this same file, for example WaterJug_Desert.igs.igs, it will load and render fine.
Exporting from Blendigo using the default.igs works fine with no errors
Doug
Doug Armand
SmartDen
Re: Error using Blendigo 1.1.18 and Indigo 2.0.5/6
Post by SmartDen » Wed May 20, 2009 2:54 am
Doug Armand wrote:Using Indigo 2.0.5/6 x64, Win 7 x64, Blendigo 1.1.18
Win 7!? :shock: wow
sorry i can't say why it happens. it can be a win7 issue. i have no problems under winxp
Check normals, dude!
Doug Armand
Post by Doug Armand » Wed May 20, 2009 3:15 am
Any chance your working on an update of Blendigo?.....wouldn't mind playing with motion blur for one :D
Doug
Doug Armand
SmartDen
Post by SmartDen » Wed May 20, 2009 8:45 pm
i'll update soon
Post by OnoSendai » Thu May 21, 2009 10:58 am
Maybe the path to the scene file is incorrect. Hard to test that hypothesis, though.
