Indigo Renderer 2.0.6
Re: Indigo Renderer 2.0.6
Rafaello, I tried to answer to your concern. Please follow the link below:
http://www.indigorenderer.com/forum/vie ... 666#p73666
[quote="zeitmeister"]Can't initialize Indigo beta 2.0.6 for Mac. :-([/quote]
I can confirm the same problem here.
Can you guys please add 'indigo_console' for the next Mac build and make sure that it works to launch from the command line with optional parameters (IGS file, output file, etc.)? I really need this to get material previews working on the Mac.
Thanks.
Thanks.
Re:
[quote="Rafaello"]Hi Ono, it's getting better and better, but I want to know about some shadows that appear in the render as I posted here http://www.indigorenderer.com/forum/vie ... =27&t=5796, they appear in 2.06 aswell[/quote]
Hi, I´m also getting strange "shadows".
It´s a very simple and clean scene - and they don´t appear, if rendered with indigo 1.1.16
- Bvers206.jpg (50.73 KiB) Viewed 9402 times
- pixie
Re: Re:
[quote="thiloo"][quote="Rafaello"]Hi Ono, it's getting better and better, but I want to know about some shadows that appear in the render as I posted here http://www.indigorenderer.com/forum/vie ... =27&t=5796, they appear in 2.06 aswell[/quote]
It´s a very simple and clean scene - and they don´t appear, if rendered with indigo 1.1.16[/quote]
It has scale issues...
I don't get it, all my scenes were rendered ok with previous versions of Indigo, no scale or geometry issues before, I'm trying the new versions of Indigo with my old scenes and the new scenes are rendered with 1.1.18. I had to melt triangles in one mesh and subdivide other to correct it to work with 2.06, so I don't think the problem is in the scenes.
well scale issues...
you are right, that I get rid of the shadows, if I scale down the scene. But then my drawing units are not 1m anymore, but 10m (or even 100m). And it´ll get messy, when adding lights.
I also could divide the surface in smaller pieces.
But both methods are not really practical.
Thiloo, since I'm curious, and since that should be reasonably lightweight, could you please attach the (unfixed) igs (zipped or with an accepted extension) ?
Just out of curiosity really, I didn't run into that issue yet that's why I'm asking, thank you in advance.
Hi Thiloo,
Can you please post the scene here, or email it to me?
(nick at indigorenderer.com)
sorry for not replying earlier,
was on a short-holiday over the extended weekend.
attached the file.
thanks for looking into it.
attached the file.
- stest.zip
- (3.07 KiB) Downloaded 406 times
No uninstaller? I'm trying to figure out some application conflicts ...
What about linux 64 release?
thanks
thanks
- PureSpider
Re:
---Rafaello wrote:I don't get it, all my scenes were rendered ok with previous versions of Indigo, no scale or geometry issues before, I'm trying the new versions of Indigo with my old scenes and the new scenes are rendered with 1.1.18. I had to melt triangles in one mesh and subdivide other to correct it to work with 2.06, so I don't think the problem is in the scenes.
Got that problems on a scene of mine recently, too.Rafaello wrote:Thank you both, I melt the triangles in a mesh and everything Ok, but in another scene I have to triangulate a mesh to make it work, so I'm confuse and I think the problem is in Indigo, because with the 2.02, 2.03 and 2.04 versions I had no problem with the same scene.
Definitely not a problem of our geometry as 1.1.18 works just fine with it!
anyone get the command line options to work, especially with respect to image and igi file output paths?
I added the command line options into a shortcut file, and Indigo does not save anything
