Indigo Renderer 2.0.6
Hi all,
This release contains some bugfixes, but also the network rendering process has had some work done on it to make it a bit easier to use.
Check out this tutorial to see how to start a network rendering with 2.0.6. Feedback welcome!
And feel free to improve the tutorial.
http://www.indigorenderer.com/wiki/network-rendering
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_2.0.6_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_2.0.6_Setup.exe
[edit] Indigo for os x:
http://www.indigorenderer.com/dist/beta ... seimage.gz.
Changelog:
2.0.6
* Added -hardwareid command line option, prints out hardware ID string.
* removed "WARNING: Overriding material definition for .." message
* Added render thread priority combobox to gui (only for windows)
* Added Network rendering option and pane to GUI; shows all connected slaves.
* Added Network slave GUI (enabled when -n s is used.)
* Fixed recent files list
* Fixed crash with emitting glossy transparent material.
* Following include links in preliminary scene parse
* Windows installers now create shortcuts to Network Slave GUI.
* moved tree_cache and network_cache into cache
Changelog:
2.0.6
Re: Indigo Renderer 2.0.6
Good improvement in terms of network rendering UI feedback. Very well done!
R.
R.
Very nice update.
I really love the improved network rendering.
Also the new slave window is very cool.
+ Thanks for so quick bug fixes.
- zeitmeister
I've got a question:
Is it too complicated to compile the Mac version along the Windows or Linux versions, or what is the reason why there aren't neither builds of the 2.05 nor the 2.06 beta?
Do I have to imply to that when I buy Indigo for Mac?
Don't get me wrong, I'm not trying to bully in any way, I am just wondering.
Hi guys! Hi Ono! Thanks for the update!
Listen, I've got a tiny annoying thing going on: the icons of "Indigo.exe" and "Indigo Renderer Network Slave.exe" are the generic icons windows uses for generic executable apps (white rectagle with a blue string in the top), and not the fancy-coloured one which I can see in the header here, for example. How can I fix that?
I'm running Indigo on Win XP 32bits.
Thank you guys.
Thank you guys.
- pixie
IMO the thread's priority should be 'below normal' as default... it's always easier to turn it normal then it is to turn it below normal
- Doug Armand
Get this error message when I try and render by exporting from Blendigo. The .igs gets created ok and
I can load it direct from the Indigo GUI and it then renders fine
Blender 2.49a, Win 7 RC x64, Blendigo 1.1.18
- Error206.PNG (10.23 KiB) Viewed 36285 times
- PureSpider
I bet its the space in the filename :D
- Doug Armand
[quote="PureSpider"]I bet its the space in the filename :D[/quote]
What space? either way it worked for versions prior to this
- PureSpider
"Dougs Stuff" that one
- zeitmeister
Very very nice, thanks a lot!
- Doug Armand
[quote="PureSpider"]"Dougs Stuff" that one[/quote]
hehe you may be right - but I've always used that folder name. I've since tried a new file in that same folder structure and that seems to render fine. Not sure whats causing it.
- Doug Armand
same error again but different file. As before exporting from Blendigo gives this error message. I can then load the .IGS file and it works. The only space in this is the folder 'Dougs stuff'. But I have had that same folder structure for ages so I think this is something else.
- erroragain.PNG (10 KiB) Viewed 36143 times
- zeitmeister
Can't initialize Indigo beta 2.0.6 for Mac. :-(
- Bild 1.png (16.11 KiB) Viewed 36134 times
Hi Pibuz,Pibuz wrote:Hi guys! Hi Ono! Thanks for the update!
Thank you guys.
The icons aren't working on XP, but only Vista for some reason. I'll fix that soon.
