by fused » Fri May 15, 2009 7:59 am
pixie wrote:Thanks for the info!
Does anyone know what filetypes are supported and how do I know what materials are applied...
You mean when using the Indigo Instance object with an external file?
supported filetypes are: *.igmesh, *.ply, *.obj and *.3ds
Materials... you have to know what the names of the applied materials are and then create materials with the same names. there is just no other way currently.
by pixie » Fri May 15, 2009 8:18 am
fused wrote:pixie wrote:Thanks for the info!
at least with igmesh it should be easy to accomplish
pixie on Sun May 17, 2009 9:38 am, edited 1 time in total.
by fused » Sun May 17, 2009 9:28 am
well, heres the new Indigo instance as a seperate plugin, have fun testing an playing
- Editor Instance v0.1 R10 Win.zip
- (152.76 KiB) Downloaded 363 times
by fused » Mon May 18, 2009 12:18 pm
editor instances v0.2
fixed issues with generators, control objects and so on.
- Editor Instance v0.2 R10 Win.zip
- (152.85 KiB) Downloaded 328 times
by pixie » Mon May 18, 2009 9:04 pm
fused wrote:editor instances v0.2
This instance is way better then the original. I can make the cloner object editable and still keep instances instead of the original meshes! Great job Yves!
by fused » Wed May 20, 2009 1:00 am
indigo instance 0.3, mac only this time. pc version will follow tonight.
-instances will be created at the position of the original object
-when multiple objects are selected it creates instances of each explicitly selected object (thx to zom-b for that idea, i think its great)
- Editor Instance v0.3 R10 Mac.zip
- (131.61 KiB) Downloaded 360 times
tungee
by tungee » Wed May 20, 2009 1:01 am
Hi Fused,
nice plugin.
When will be the 9.6 version of the plugin and exporter on the way ?
Im eager to test.
by fused » Wed May 20, 2009 1:12 am
R9 verison of the instance plugin is easy, i might do that tonight, cindigo R9 is a bit more complicated, but i will try that tonight, too.
by Zom-B » Wed May 20, 2009 6:40 am
Thanks a lot fused, great work!
This two new features will help a lot!
I will try it immediately on a scene I'm working on atm!
by pixie » Wed May 20, 2009 6:43 am
fused wrote:0.3 for Win.
What are the new features?
by Zom-B » Wed May 20, 2009 6:49 am
pixie wrote:fused wrote:0.3 for Win.
Here you go
by pixie » Wed May 20, 2009 6:58 am
fused wrote:indigo instance 0.3, mac only this time. pc version will follow tonight.
OMG, you're beating Cinema's instances on their own game! :O
Users browsing this forum: No registered users and 87 guests
