M2I 0.612
- Kosmokrator
Re: M2I 0.611
Hereu3dreal wrote:Hey all,
Ok so here is the latest Exporter for 3D Max..
Make sure you read the "Readme First" carefully to get all features.![]()
Get it here !
cheers
u3dreal
u3dreal
- Kosmokrator
ok i have done the sharing to slaves but the strange error msg
"--no ""+"" function for ok" its still there!i think this an exporter bug man.....what do u think?
- Kosmokrator
- Kosmokrator
maybe some network configuration dont let me see the slave? damn!
- Kosmokrator
the drive on slave (i use 1 slave for the moment...) i have set full acces
what files u mean to copy manual?
here is the .bat
@ECHO OFF
Echo IndigoRunSlaves...
REM Remove REM to enable copy of bat file to Slaves.....
copy C:\Indigo\IndigoNetSlave.bat \\mk-sz8sklt39idi\Indigo
REM copy C:\Indigo\IndigoNetSlave.bat \\Lisa\Indigo
REM copy C:\Indigo\IndigoNetSlave.bat \\Homer\Indigo
REM Remove REM and Exchange Simpsons Names with Slaves Names
REM In this case LISA,BART and HOMER are NetSlaves..
psexec \\mk-sz8sklt39idi -u mk-sz8sklt39idi\Indigo -p Indigo -i C:\Indigo\SlaveRun.bat
REM psexec \\BART -u BART\Indigo -p Indigo -i C:\Indigo\SlaveRun.bat
REM psexec \\HOMER -u HOMER\Indigo -p Indigo -i C:\Indigo\SlaveRun.bat
REM NOTE: psexec will not run on Win XP Home as far as i know
REM If you get it to work plz mail me ....see readme
EXIT
here is the .bat
@ECHO OFF
EXIT
check if the IndigoNetSlave.bat gets copied ... delete the old one in slave dir.
if this works run the IndigoNetSlave.bat manually on slave...
If this works we can go on ..
cheers
u3dreal
- Kosmokrator
ok i have run manually the bat file in slave computer and....indigo found the textures,xml file ,exr files on master but... eventualy show this erron and stop....
damn network!
- Kosmokrator
ok now works fine!!!its my fault! but i have an other problem now....when tha indigo try to save the png image i take this in console..
and the file .png is black,nothing saved...!!!
- Kosmokrator
- Kosmokrator
how exactly works indigo coop rendering?the calculations of slaves transfered to master and added to master calculations?
or the image transfered and "Mixed" with others to make a beeter result?
