problem whit object
10 posts • Page 1 of 1
filippo
problem whit object
Post by filippo » Sat Dec 09, 2006 11:34 pm
in some sceneses, in the render the objects don't have the same position of the scenes why?
in alcuni render gli oggetti non hanno la stessa posizione della scena
perche?
ciao filippo
u3dreal
Post by u3dreal » Sun Dec 10, 2006 1:15 am
Yes i would also like to know...same happens with xml and 3ds..
NO IDEA .. if anyone has let em know.
cheers
u3dreal ;)
PS this only happens with some imported objects/scenes..:roll:
Post by OnoSendai » Sun Dec 10, 2006 4:16 am
This is an indigo bug?
Can u describe it in more detail?
filippo
Post by filippo » Sun Dec 10, 2006 5:03 am
this is the scene that I have prepared
cam 1 view
total error
u3dreal
Post by u3dreal » Sun Dec 10, 2006 6:32 am
No nick this is not an Indigo bug .. this also happens when i export to 3ds.. :) no worries..
cheers
u3dreal ;)
filippo
Post by filippo » Sun Dec 17, 2006 9:30 am
I continuous to have this problem, with many files, also dwg.I find a solution, to import the 3ds in rhinoceros 3d, and re-export the file in 3ds.
only in this way has been possible to resolve the problem.
same problem is also had with maxwell render when it work in 3ds from max
filippo
Post by filippo » Sun Dec 17, 2006 9:51 am
:oops: !!!sorry, but in a little number of scenes the problem decreases, but it remains, some objects change position,
Post by CTZn » Sun Dec 17, 2006 10:22 am
Did you try to reset transforms as well as scale, like afecelis show here ? Seems logical, in case the exporter fails to translate coords at least for 0 0 0 that shouldn't be an issue...
Resetting transforms will place every objects coords to 0 0 0 without moving them.
filippo
Post by filippo » Sun Dec 17, 2006 10:56 pm
this it is a good idea, but it doesn't work, such operation, brings the objects to the posizione\scale as in origin, but only if created in max., if the object was created in a other modeler, the objects, move where they want
Post by CTZn » Mon Dec 18, 2006 6:43 am
Ok, my bad...
