Cindigo 1.1.18 - stable RC4
Post by fused » Mon Apr 20, 2009 10:54 am
for Indigo 1.1.18
download exporter:
Pc Version
Mac Version - soon
The PC version contains plugins for R10(32 and 64 bit) and R9(32 bit). R9 users will have to rename the "cindigo.cdl_R9" to "cindigo.cdl".
Make sure you have the newest version of quicktime installed! Previews will not work with the 64 bit version bacause of the lack of 64 bit quicktime.
Good beginner tutorials can be found here (german and english, a bit outdated), a video tutorial for beginners here
The Cindigo Blog
changelog wrote:Cindigo 1.1.18 (stable RC4):
* removed Obase from render settings object
* merge_vertices_with_same_pos_and_normal = false
* added hiding of texture parameters if no texture is used
* fixed a Quick Render crash bug
* added Quick Render button, few restrictions:
indigo always runs, no specifying png output, geometry will always be exported, no animation export.
all other settings will be used from the settings.cfg
* the linked materials will not be recalculated on each change made to the material helper
* added "channel state" that indicates whats applied to the chosen channel
* added option to choose which c4d channel should be used for albedo, bump, emission, etc.
* added emission scale export to bg material
* material helper adopts the layer of the applied material (R10 only)
* removed light scale tag
* moved light scale settings to material helper
* disabled channels wont be exported anymore
* removed emission scaling from sphere, its not supported yet
* background material setting in render settings now uses a material helper tag
* removed background and envmap from render settings, added background material
* exchanged <blend_factor> with <blend> for constant values
* added <random_triangle_colours> to diffuse material
* spheres and external models can use light scaling now
* added glowing icon for material helper if emission is used
* fixed that exit portal gets exported, even if its disabled in the tag
* renamed "light normalization" to "light slcaling"
* removed infinite plane
* added verbose = false and write_aperture_preview = false to preview scenes
* changed save period for previews to 10.0
* added import of ISL shaders
* added ISL shader
* restructured and rewrote parts of the material export
* added "Ok" button to about dialog
Do you like Cindigo? Remember it is free.
If you think its valueable software, please feel free to donate.
Cindigo 1.1.18 RC4.zip
(3.5 MiB) Downloaded 777 times
Re: Cindigo 1.1.18 - stable RC4
Post by Zom-B » Mon Apr 20, 2009 7:04 pm
I love this XXL changelog, great work fused, thanx a lot :D
iacx
Post by iacx » Mon Apr 20, 2009 7:09 pm
Thanks Fused, great!
mrmoose
Post by mrmoose » Mon Apr 20, 2009 7:45 pm
Thanks Fused ;)
Post by pixie » Mon Apr 20, 2009 9:00 pm
You're the man Fused! :D
tungee
Post by tungee » Mon Apr 20, 2009 10:21 pm
Thanx fused!
You are the man! :wink:
carsten_fokuspunkt
Post by carsten_fokuspunkt » Tue Apr 21, 2009 1:35 am
great work fused!! thanks a lot.
this is a long long list of changes....
Camox
Post by Camox » Tue Apr 21, 2009 1:40 am
:D Thank fused, I hope we can now use one before everything is commercialized.
greetz :wink:
Post by fused » Tue Apr 21, 2009 3:43 am
carsten_fokuspunkt wrote:great work fused!! thanks a lot.
carsten_fokuspunkt,
if you didnt know already: a rendering of you is used on the cindigo page ( http://www.indigorenderer.com/documentation/cinema4d ), i hope this is ok for you!
also, id love to see more such renderings produced with cindigo and indigo, hope to see more ;)
carsten_fokuspunkt
Post by carsten_fokuspunkt » Tue Apr 21, 2009 6:14 pm
hi fused,
i saw it last friday and this made my day brighter :)
sure, its ok!
hope to get the time for further projects :(
carsten
Marcofly
Post by Marcofly » Wed Apr 22, 2009 1:25 am
Hi fused! thank you very much for the release! i finally found the time to download and play a bit with it, and it works fine!
I found a bug, related to the label of the wine bottle: the second pic shows a cinema AR-render, and that's how the label should be. The first pic is an Indigo one (1.16), and although i unckecked the 'tile' option in C4D, the label texture gets repeated in the y-axis, covering the whole area of the selection. The texture 'offset x and y' of cinema doesn't work, either..
ciao!!
Post by fused » Wed Apr 22, 2009 1:42 am
Marcofly wrote:Hi fused! thank you very much for the release! i finally found the time to download and play a bit with it, and it works fine!
ciao!!
hey Marco!
glad you found some time :)
what you found is not a bug. its currently not supported by indigo to turn off tiling. nice rendering!
Post by pixie » Wed Apr 22, 2009 1:45 am
And they keep on saying wonders around AR3 glass... :?
Marcofly
Post by Marcofly » Wed Apr 22, 2009 3:27 am
pixie wrote:And they keep on saying wonders around AR3 glass... :?
Pixie, this isn't a good example of AR3 glass.. but it renders FAAAAAST! :wink:
Thanks fused! Now i have to learn how to put 2 lights on separate layers.. will search the forum first!!
ciao!
Post by pixie » Wed Apr 22, 2009 3:32 am
ciao!
On material helper when emission is chosen you can set the number for the layer of the given light
Users browsing this forum: Google [Bot] and 44 guests
