Helmer - A relatively cheap home renderfarm
Well it's a bunch of motherboards in a metal cabinet. Though it's quite fast for its price.
http://helmer.sfe.se/
- joegiampaoli
Similar project with GPUs:
http://fastra.ua.ac.be/en/index.html
They beat a 3.5mio $ computer with this machine!
PS.: I'm not a fan of GPU vs. CPU.....but in this case the GPU-solution seems quite effective.
Just add more cores!!!111one
Well, Tesla is the "pro"-Version of that "FASTRA" thingie - however I wonder how they managed to:
- cool the GPUs effectively (there is no mainboard in there as far as I could see) 1500 Watts is not very efficient... maybe they should use some more dedicated hardware than 9800X2 cards (maybe even AMD/ATI cards, they are even cheaper)
- get a mainboard to accept 8 GPUs on 4 PCIe lanes (looks custom built...)
- get this guy to make the video, he just looks like all of those geek-stereotypes in one person
- build that much *bling* in one workstation
Edit: CUDA-Indigo anyone?
there is, the CPU Coller is just a hintSukrim wrote:(there is no mainboard in there as far as I could see)
if CUDA is involved ATI Cards are dismissed... aren't they?!Sukrim wrote:1500 Watts is not very efficient... maybe they should use some more dedicated hardware than 9800X2 cards (maybe even AMD/ATI cards, they are even cheaper)
wasn't new even in 2005 -.-Sukrim wrote:get a mainboard to accept 8 GPUs on 4 PCIe lanes (looks custom built...)
+1 I love his clumsy gestures ^^Sukrim wrote:get this guy to make the video, he just looks like all of those geek-stereotypes in one person
In a Galaxy far far away... in a Time of 4GB RAM on board, GPUs working with double prezision there is a Indigo Cuda version ^^Sukrim wrote:Edit: CUDA-Indigo anyone?
- cookieofdoom
Check Google about the Coler Master 20 ghz 53GHz Mini-itx PCMeelis wrote:Isn't there PSU-s that supports multible motherboards? Maybe server one.
water cooling wood be nice to.
http://www.minitechnet.de/typo3temp/pics/22a19c8d43.jpg
Here a german article: http://www.minitechnet.de/cooler-master ... itx_1.html
The idea was to power 5 mainboards with one PSU and bring all in one Case... watercoled!
The PSU was slightly modified for this purposes, but seems to be easy to reconstruct!
It's totally assom.
Will unmodified psu drive it. I really don't know how do modifie.
Tagan - BZ1300 might work maybe
http://www.tagan.com/index.php?option=c ... Itemid=143
It has 1104W on six +12V rails.
I'm going to burn everything down someday if i start modifing
Its explained at some point in one of the videos shortly. 5x Cooler Master 12V DC-DC Mini-Converter 160W re used for this purpose!Meelis wrote:It's totally assom.![]()
I'm going to burn everything down someday if i start modifing![]()
The idea is to have one workstation, that can be used by 5 users at the same time. every of the systems here got a own burner, HDD etc.carbon wrote:only 2gb memory each?![]()
and why 5 burners?
I imagined that dc 2 dc converter inputs req volts from PSU's +12V rail, not like most single iTX system do from ac adapter's. Didn't they modifie converter dc-in to input from psu's +12V rail.Its explained at some point in one of the videos shortly. 5x Cooler Master 12V DC-DC Mini-Converter 160W re used for this purpose!
PSU calculator told me I need 210W for: Q9550 / 4x ddr2 / 3.5 7200 sata HD / DVDRW drive. How can i share one HD & one DVD drive between motherboards.
