Blendigo for 1.1.14
Jambert
Post by Jambert » Wed Mar 18, 2009 8:10 pm
Hi smartden,
is it possible, in next release, to add peak value in sss?
an exemple of CTZn's material
<scenedata>
   <medium>
      <name>dichro_medium</name>
      <precedence>6</precedence>
      <basic>
         <ior>1.393849969</ior>
               <rgb>
                  <rgb>6 3.5 3</rgb>
                  <gamma>2.2</gamma>
               </rgb>
         <subsurface_scattering>
               <rgb>
                  <rgb>11 6 14</rgb>
                  <gamma>2.200000048</gamma>
               </rgb>
            <phase_function>
               <henyey_greenstein>
                  <g_spectrum>
                     <peak>
                        <peak_min>485</peak_min>
                        <peak_width>80</peak_width>
                        <base_value>-0.065</base_value>
                        <peak_value>0.72</peak_value>
                     </peak>
                  </g_spectrum>
               </henyey_greenstein>
            </phase_function>
         </subsurface_scattering>
      </basic>
   </medium>
   <material>
      <name>previewmaterial</name>
      <specular>
         <internal_medium_name>dichro_medium</internal_medium_name>
      </specular>
   </material>
</scenedata>
Thanks
Jambert
Post by Jambert » Thu Mar 19, 2009 8:50 am
Another problem, could you change max number of threads to 8, with corei7 it auto detect 4 threads but I have 8 nodes :wink:
Thanks
sorry for my poor english
edit: I don't understand why but autodetect work with indigo_console
neepneep
Post by neepneep » Sun Mar 22, 2009 1:20 pm
There is still no (easy) way to export animations where the mesh and material of an object changes. The only thing that is exported is the mesh & materials of the first frame, and then just the loc/scale/rot of the object for the rest of the anim.
Could there be an option to toggle either a 'full' export of frames (mesh+material+object transformations of each frame) or a 'quick' export of frames (object transformations only - as it is now) ?
SATtva_
Post by SATtva_ » Sun Mar 22, 2009 6:15 pm
neepneep, I think in case of mesh transformations you're supposed to apply all transformative modifiers before exporting, so in each frame you'll have a distinct mesh.
doublez
Post by doublez » Wed Apr 08, 2009 2:05 pm
I followed the guide to use isl in blendigo, but when I make a new text block it doesn't show up in the list of shaders like its suposed to. What am I doing wrong.
http://www.indigorenderer.com/joomla/co ... go_shader/
Post by Borgleader » Wed Apr 08, 2009 2:18 pm
doublez wrote:I followed the guide to use isl in blendigo, but when I make a new text block it doesn't show up in the list of shaders like its suposed to. What am I doing wrong.
did you make sure the block was called isl_something
doublez
Post by doublez » Wed Apr 08, 2009 11:48 pm
That fixed it. Thanks borg :D
Re: Blendigo for 1.1.14
Post by Borgleader » Thu Apr 09, 2009 10:16 am
Np, glad all is fixed for you :)
kampret06
Post by kampret06 » Sun Apr 19, 2009 4:40 am
hi there..
i`m new in blender.. and indigo of course..
i got some problem when installing blendigo.. i`ve use the windows installer but when i try to run blendigo on blender 2.48a it`s show me an error message -> "phyton script error: check console"
and i don`t know where the problem is.. :cry:
i`ve try to use both 1.1.14 and 1.1.15 version of indigo and the problem are still there.
regard,
adhi
Post by Borgleader » Sun Apr 19, 2009 4:45 am
what does the console say?
kampret06
Post by kampret06 » Sun Apr 19, 2009 8:39 am
this is what the console said:
file "I:\Documents and Settings\hehe\Application Data\Blender Foundation\Blender\.blender\scripts\blendigo_v1114.py", line 2922, in <module>
print "Blender datadir"+Blender.Get<"datadir">
TypeError: cannot concatenate 'str' and 'NoneType' objects
SmartDen
Post by SmartDen » Sun Apr 19, 2009 10:20 pm
1.1.18 is almost done
Check normals, dude!
palawat
Post by palawat » Sun Apr 19, 2009 10:46 pm
WOW ! That's good news, SmartDen.
I haven't played with Indigo for a while and very exited for the new Blendigo. Thank you very much for your work.
Cheers,
Post by Borgleader » Mon Apr 20, 2009 1:03 pm
SmartDen wrote:1.1.18 is almost done
Niiiiice :) Must we expect new features and such?
Pinko5
Post by Pinko5 » Mon Apr 20, 2009 7:17 pm
:D :D :D good news Smart!!!
Luca. ;)
