SkIndigo 1.1.16 and the fireflies
Post by CTZn » Tue Apr 07, 2009 9:21 am
I use gaussian as splat, Pibuz (box is rude I think !).
Gaussian is told to be blurry but downsizing (with mn_cubic eventually) instantly alleviates the argument, and it does not underline contrasts. But on that last point, one may want to experiment with the mn_cubic settings. I heard a mental ray user happy with both blur and ring set to 0.5 iirc.
fused is right about the version Pibuz, don't fight against bugs, switch to 1.1.18 !
On a second note it will be interesting to track the modeling habits that might induce fireflies, for instance when mediums are intersecting with normal materials I believe. Remember to always keep glass panes at a distance from their support, that's the way they should be. The same rule applies for lampshades using mediums, a glass on a table etc.
Post by Pibuz » Tue Apr 07, 2009 7:37 pm
Sorry to bother you CTZn, but I'm not so expert about encoding and stuff.. :oops:
This is the xml file I found in the Indigo root folder, I suppose that's the configuration it uses while rendering:
<config>
<renderer_settings>
<metropolis>false</metropolis>
<downsize_filter>
<!--<box/>-->
<mn_cubic>
<ring>0.2</ring>
<blur>0.6</blur>
</mn_cubic>
<!--<gaussian></gaussian>-->
</downsize_filter>
<super_sample_factor>2</super_sample_factor>
<aperture_diffraction>true</aperture_diffraction>
<post_process_diffraction>true</post_process_diffraction>
</renderer_settings>
</config>
Which parameters should I change in order to have your configuration?
Sorry CTZn...
No hurry: write when you have some spare time to waste...
Re: SkIndigo 1.1.16 and the fireflies
Post by CTZn » Tue May 26, 2009 9:52 am
Sorry CTZn...
Oh Pibuz I am sorry, I did not mean to give you no answer ! I was looking for some informations today when I finally saw your post...
Mostly, I am always using a MLT-bidir combo, though we can tell by the inifile that the idea might not please Ono very much :oops:
And well, by the same inifile we can't say wich is the default splat filter used by Indigo; using MtI I always set it to gaussian, though since supersample is on by default, box should fit better. If supersample was to be set to 1 (ie, disabled), I for one would use the former as splat filter. If you want to try it out, add the following to the <renderer_settings> (though it might well be Indigo's default already :?: ):
	<splat_filter>
		<gaussian/>
	</splat_filter>
Again, excuse me for the latency, and sorry for bumping a 1.1.16 related thread...
Storm now, shuting down 8)
