Cindigo 1.1.18 - stable RC2
Rafaello
Post by Rafaello » Tue Mar 17, 2009 5:50 am
Thank fused, I'll post the scene as soon as I get home so you or any one else can play with it, it's just cinema's hair. :)
Well... here is the scene, hope you find it helpfull.
Pelos.zip
Instanced carpet
(688.99 KiB) Downloaded 344 times
Post by fused » Tue Mar 17, 2009 6:18 am
i was implementing the background material and i was wondering,
how would you guys like it better:
- all relevant settings in the render settings object
- a link to a material defined in a mat helper
Post by pixie » Tue Mar 17, 2009 6:37 am
I didn't quite get it, could you please explain it better?
Post by fused » Tue Mar 17, 2009 6:56 am
hihi, it should say "background material" instead of "material helper" XD
Post by pixie » Tue Mar 17, 2009 8:50 pm
Perhaps it should be a material as any but when applied to the cinema's sky object it wold then become "background material tag"
Post by pixie » Tue Mar 17, 2009 10:18 pm
The scene crashes whenever I try to work on a given material
Untitled 2.rar
crashing scene
(533.89 KiB) Downloaded 314 times
Rafaello
Post by Rafaello » Wed Mar 18, 2009 11:16 am
Hey pixie, can you tell me what material crashes when you work with it? the only problem I had with your scene was with the missing textures applied to the floor material.
Post by pixie » Wed Mar 18, 2009 11:33 am
all were crashing I think... I'll post you the textures once at work
iacx
Post by iacx » Wed Mar 18, 2009 8:09 pm
Hello to all, with the pixie file I have the same problem I had with my file. Cinema is blocked by calling the Microsoft Visual C + + Library.
At this point I think in my case the problem is the operating system or driver. :(
Post by pixie » Wed Mar 18, 2009 10:30 pm
There's an introduced discrepancy between viewport and the final render that is also induced into Cinema own rendering system.
Post by pixie » Wed Mar 18, 2009 10:36 pm
From what I gathered it has to do with the ratio... I also have to manually change it on cinema and all is good
Post by pixie » Thu Mar 19, 2009 1:11 am
The extra Material doesn't work :(
Post by fused » Thu Mar 19, 2009 3:00 am
fused wrote:oh, btw: the "external igm" material type isnt working yet...
Post by pixie » Thu Mar 19, 2009 3:01 am
I was just expressing my frustration :p
Post by PureSpider » Thu Mar 19, 2009 3:10 am
pixie wrote:There's an introduced discrepancy between viewport and the final render that is also induced into Cinema own rendering system.
Yep, just click on the Indigo Camera Tag once and the ratio will change :)
That's my workaround for this bug... never bothered to report it though... sorry fused
