for Indigo 1.1.17 and Indigo 1.1.18
download exporter:
Pc Version
Mac Version - no mac version available yet!
PC version contains plugins for R10(32 and 64 bit) and R9(32 bit). (R9 users will have to rename the "cindigo.cdl_R9" to "cindigo.cdl")
Make sure you have the newest version of quicktime installed! Previews will not work with the 64 bit version bacause of the lack of 64 bit quicktime.
Good beginner tutorials can be found here (german and english, a bit outdated)
a big "thank you" goes out to PureSpider, who did a great job and coded lots of useful stuff for this release!
please tell me if you find bugs or have specific requests. i will try to fix/implement as fast as possible.changelog wrote:Cindigo 1.1.18 (stable RC1):
* move to Indigo Utils v2
* fixed emission import
* solved memory problems (normal array wasnt freed after mesh export) (fused)
* rewrote igm import, now using Indigo Utils (fused)
* wrote load function for indigo path and itegrated it into the gui (fused)
* changed load and save functions internally, indigo path is now saved in the settings.cfg (pSr)
* changed a few defaults (aperture shape, ssf, etc.) (fused)
* added random seed (pSr)
* reworked mesh and instance export, (hopefully) fixed all related bugs and added support for nested instances (fused)
* Indigo Instance now shows bounding boxes of child elements (fused)
* Material hepler is now an object instead of a tag. Changed all functions according to that (fused)
* added own object for imported/converted materials and moved all converted materials to a single group, even on multiple material converts (pSr)
* export dialog remembers the last settings (pSr/fused)
Do you like Cindigo?
If you think its valueable software, please feel free to donate.
Please split the donation in two and donate the other half to Indigo.
