C++ code for reading Indigo materials
13 posts • Page 1 of 1
Post by OnoSendai » Thu Mar 05, 2009 9:25 pm
Hi all,
I'd love to see some of the exporters for various modelling packages support importing Indigo materials, so that the MatDB can start becoming really useful.
But I realise that writing the code that can process a .igm file can be pretty difficult and time-consuming, especially when you have to cope with backwards compatibility in material XML specification.
So I'm releasing some C++ code that can parse Indigo materials, given the XML element. The XML parsing itself is done with TinyXML.
For the people that are working on an exporter that doesn't use C++, well, at least the code can provide a guideline of what needs to be done.
I've just been working on this over the last few days, so it's not fully tested yet.
However, this code should be pretty complete, and will be maintained in the future, as it's now also the code that Indigo uses to parse material XML.
Any feedback is welcome. Is this useful for exporter authors?
indigo_utils_2.zip
(30.93 KiB) Downloaded 1202 times
Re: C++ code for reading Indigo materials
Post by fused » Thu Mar 05, 2009 9:40 pm
OnoSendai wrote:Is this useful for exporter authors?
Yes!
Post by suvakas » Thu Mar 05, 2009 10:07 pm
Great idea !
Can't use it from Maxscript, but still..very good idea.
Post by CTZn » Fri Mar 06, 2009 12:19 am
Nice move Ono !
This can certainly avoid some hassle and borrow some incertitudes (design wise), aye to the guidelines !
rgigante
Post by rgigante » Fri Mar 06, 2009 2:18 am
:shock: A lot of great thing to study and apply!
Thanks, really really appreciated...(psss IT4XSI supports IGM since long ago :wink: )
R.
Post by Whaat » Fri Mar 06, 2009 2:49 am
Great! Thanks Ono! This is sure to be extremely useful for all exporter writers. I just wished I had asked for this a long time ago... :) My material import code is almost done, I just need to spend about a week bug-fixing and testing it. :)
Post by fused » Fri Mar 06, 2009 12:31 pm
hey nik,
i dumped the old cindigo import code and completed the material import using your parser. still need to do the texture loading (yeah, i said itll be ready today, but i got heavily distracted by MGS4, Mirrors Edge and failblog.org ^^ ).
on the way i noticed that i really have to rewrite the material helper... im not sure if i can do that before 1.1 stable.
i also have a little problem here: it seems the gamma value in the RGB spectrum is missing!
Post by OnoSendai » Fri Mar 06, 2009 2:01 pm
fused wrote: i also have a little problem here: it seems the gamma value in the RGB spectrum is missing!
Hi Fused,
sorry, what exactly do you mean by that?
Post by fused » Fri Mar 06, 2009 9:34 pm
OnoSendai wrote:Hi Fused,
i mean that there is no gamma variable in the IndigoRGBSpectrum but the xml rgb spectrum can hold rgb and gamma.
edit: i had a closer look at your source code and gamma is parsed and the color gets reverse gamma corrected... but im not sure if this is suitable :) (at least for my needs)
edit2: also i couldnt find a function for parsing mediums
Post by OnoSendai » Sat Mar 07, 2009 11:54 am
Parsing media is not supported in the Indigo Utils yet, because strictly speaking they're not materials. However, since they are needed for .IGM import, I might add them in.
Post by fused » Sat Mar 07, 2009 1:42 pm
no problem, since they didnt change at all in the last material specs i still have the old code which is working ok for now.
Post by OnoSendai » Sun Mar 08, 2009 3:24 pm
Updated to v2 with some backwards compatibility fixes.
Post by fused » Sat Mar 28, 2009 11:16 am
im having some problems with gcc and exceptions with the indigo utils.
without -fexceptions im getting errors on try {} catch {} and with on throw...
cant tell more about right now, but maybe sounds familiar for someone :)
