Blendigo for 1.1.14
SmartDen
Post by SmartDen » Thu Feb 19, 2009 4:30 am
Jambert, 1 million is enought for perfect mirror
Check normals, dude!
Jambert
Post by Jambert » Thu Feb 19, 2009 5:18 am
I'm sure it's not enough, I made test editing manualy from 1e+007 to 1e+009, it's better but not perfect
1e+007
1e+009
Post by CTZn » Thu Feb 19, 2009 8:30 am
they look about the same Jambert :)
Again if you are after perfect uncolored mirrors use rather specular with highest ior.
Freedom for scalars !!!
Jambert
Post by Jambert » Thu Feb 19, 2009 11:12 am
ok so if nobody trust me, a high resolution with ior 3 (mirror a bit dark :wink: ) and exponent 1e+007 (editing manualy)
Post by CTZn » Thu Feb 19, 2009 6:45 pm
What if you trust me :lol:
Exponent is controlling how glossy the reflections are.
Not how much reflection is occurring.
Drop Phong, drop exponent, mirrors don't need that.
Use an opaque specular with 1.000.000 ior or more, OR, set the phong's ior to a similar value. No wonder that ior 3 is lowly reflecting, I think you are mixing exponent and ior together.
IOR defines the amount of reflections, glossy their sharpness. 3 is not enough because some real materials do have that ior, and that doesn't make perfect mirrors of them (as you verified).
Now I'm even :)
Edit: I'm liking the look of the room !
SmartDen
Post by SmartDen » Thu Feb 19, 2009 8:12 pm
Jambert wrote:ok so if nobody trust me, a high resolution with ior 3 (mirror a bit dark :wink: ) and exponent 1e+007 (editing manualy)
you should set ior as high as posibble. 3 is too low. try ior 1,000 and exp 1,000,000
Jambert
Post by Jambert » Thu Feb 19, 2009 9:39 pm
if I put ior 1000 my mirror will have no color, that all, I know that, that's not the problem?
perfect, to me, means no glossy
But 1e+007 is still glossy or blury, have a look on the left, it's not perfect...
so a test with ior 3 (darky) and exp 1e+009 :wink: no blur
exp 1e+009
Jambert
Post by Jambert » Thu Feb 19, 2009 9:47 pm
with specular and low ior you can't change color it's black, blue or orange, would be nice
but reflections are perfect, no blur :)
thanks for your help :D
Jambert
Post by Jambert » Thu Feb 19, 2009 10:17 pm
last test
SmartDen
Post by SmartDen » Thu Feb 19, 2009 11:28 pm
Jambert wrote:last test
ok, i see now. thanks for explanations.
you can download the updated script from first page
Jambert
Post by Jambert » Thu Feb 19, 2009 11:38 pm
SmartDen
Thx for your time, sorry for my poor english :oops: :D :D
SATtva_
Post by SATtva_ » Mon Feb 23, 2009 10:17 pm
SmartDen, is it possible to expand "ray nudge" field (under Renderer tab in Blendigo) from the current 5-digit to 7-digit as per exported xml? The problem is that it's not possible to enter a value below 0.0001 -- Blendigo not rounds it up for display, but just drops any fractions below that value and exports 0.000000, the effect of which you may see here:
http://www.indigorenderer.com/joomla/fo ... 9318#69318
Post by Kram1032 » Tue Feb 24, 2009 9:13 am
why would you need a lower ray nudge distance? Are you working with micro objects? O.o (I mean, the LEDs ARE small... but not THAT small O.o)
Psychotron80
Post by Psychotron80 » Tue Feb 24, 2009 9:42 am
Kram1032 ...why would you want to limit yourself to 1/10mm? I would make the exporter so that it supports the entire range supported by Indigo itself....
Post by Kram1032 » Tue Feb 24, 2009 10:54 am
hmm you'll rarely need >0.1 mm anyway but probably you're right^^
