Indigo SDK 15
Discussion for users of the Indigo Renderer SDK.
14 posts • Page 1 of 1
Indigo SDK 15
Post by OnoSendai » Thu Feb 12, 2009 6:14 pm
http://www.indigorenderer.com/dist/IndigoSDK_15.zip
Changes:
* The SDK does everything now, network rendering etc..
* You have to save the scene to disk and then the DLL will load it from disk, for now. Use .igmesh files for the meshes when doing this.
* All IndigoInterface1 method calls are non-blocking now.
Please see the example file indigo_dll_usage_example/Driver.cpp for an explanation of how to use the SDK now.
This is a bit of a WIP release, so some stuff is disabled, like getting the HDR buffer, and the documentation isn't updated.
Re: Indigo SDK 15
Post by fused » Thu Feb 12, 2009 7:53 pm
fantastic, thank you!
OnoSendai wrote:* All IndigoInterface1 method calls are non-blocking now.
:D
Post by suvakas » Thu Feb 12, 2009 7:55 pm
Hey,
A small question: Will it be the .igmesh files from now on and no direct-to-memory export?
If so, then I am sad. It doesn't fit with my plans and the logic of my project. External file doesn't make any sence when doing a full integration and not an exporter.
Please, please bring the direct to memory export back. Please?
[edit]
OK, got my answer in chat. It will be back later :) Thank you Ono!
rgigante
Post by rgigante » Fri Feb 13, 2009 2:29 am
WOW! Business light speed!
Post by fused » Fri Feb 13, 2009 12:33 pm
in case any one of you is wondering why indigo doesnt render: you need the inifile.xml inside the binaries folder.
i somewhat got it working with my plugin, but after a rendering stops c4d crashes. it seems that destroyOb() is never called, and i guess its related to that (confusing, since im using the IndigoHandle exactly like i used it in the old sdk).
it really is just a wrapper around the indigo_console.exe and definitely WIP. it does even save a png if a "renders" folder is present, with tonemapping, so make sure you set the save period very high.
i miss processXMLElement() :)
didnt try updateXMLElement() or any of the other new stuff yet, and i wont do that until i know the source of the crashes.
all in all, it was a bit annoying to get it working and im nowhere next to where i was before. i still have to rewrite the mesh export for igmesh and lots of other stuff. my code went from quite clean to ugly, confusing and full of TODO comments :P
BUT
its great to have a fully functional version! :D
now i can finally mess with interactive tonemapping ^^
Post by fused » Fri Feb 13, 2009 8:38 pm
also, the buffer returned by indigo is always 4 pixels higher/wider than the size you set (eg 320x240 / 324x244). guess thats for getting rid of the 1-2 pix dark border that was there in (much) older versions of indigo and in the old sdk.
rgigante
Post by rgigante » Sat Feb 14, 2009 12:16 am
Bigger buffer was a known "bug". But if u crop the image while displaying it's correct
2c, R.
Post by fused » Sat Feb 14, 2009 12:41 am
rgigante wrote:Bigger buffer was a known "bug". But if u crop the image while displaying it's correct
2c, R.
yep, thats what im doing, it was just a note for you guys. i didnt experience this in older sdk versions...
Post by fused » Mon Feb 16, 2009 12:22 am
ok, checked it with the older version, destroyOb isnt called the way i use it...
crashing is still confusing...
heres what i do: i have a global class that handles all the indigo stuff (for various reasons; it handles queueing and interactive tonemapping and such).
this class looks somewhat like this:
class IndigoClass
	public:
		IndigoClass() {
			indigo = IndigoHandle<IndigoInterface1>(NULL);
		Bool LoadDLL() {
		Bool CreateIndigoInstance() {
		void InitRendering() {
			LoadDLL();
			CreateIndigoInstance();
			//return TRUE;
		Bool StartRendering() {
			//check pointer
			if (!indigo.getPointer()) return FALSE;
			indigo->startRendering();
			return TRUE;
		Bool EndRendering() {
			//check pointer
			//stop rendering
			indigo->startTerminateRender();
			// Wait for rendering threads to stop
			while(!indigo->isRenderTerminated())
				GeSleep(50);
			Unload();
			return TRUE;
		IndigoHandle<IndigoInterface1> GetIndigoHandle() {
			return indigo;
		void Unload() {
			if(dll_handle != NULL)
				const BOOL res = FreeLibrary(dll_handle);
				dll_handle = NULL;
				//assert(res != 0);
		~IndigoClass() {
			Unload();
	private:
		HINSTANCE dll_handle;
		IndigoHandle<IndigoInterface1> indigo;
it does a bit more that that, but basically, thats it.
this works perfectly fine with sdk 13, with sdk 15 its always crashing with an access violation ~a second after the rendering stopped.
maybe this is just me being stupid again :)
any idea, nik (or others :) )?
(maybe the indigo handle isnt placed that well in the global class, i think ill move it out of there and put it in the part of my plugin that does the exporting and rendering.)
cheers
edit: its of course far from thread safe, but i dont worry about that for now :)
eidt: luckily thers a Semaphore class in the c4d sdk :D
Post by fused » Mon Feb 16, 2009 11:18 am
heh, never mind! there was an uuuuuuuuuuuuuuuuuuugly memory leak that caused that crash! c++ is dangerous...
or maybe it was because i was using new and delete instead of c4ds gNew/bNew and gDelete/bDelete.
no matter what the problem was - im happy :)
Post by fused » Tue Feb 17, 2009 11:22 am
thought id share this :)
Post by OnoSendai » Tue Feb 17, 2009 11:25 am
sweet :)
Post by suvakas » Tue Feb 17, 2009 7:29 pm
Indeed, looks cool. 8)
Post by fused » Tue Feb 17, 2009 8:28 pm
thx :)
i was wondering about the "white_point" xml...
is it a regular xml element i can use in the igs file or can i only use it with updateXMLElement()?
if its a regular xml element, i assume it overrides the "white_balance" in the "camera element". is that correct?
id dump the usual white points then, because this gives me more freedom plus itd allow a custom whitepoint setting without using the interactive tonemapping stuff.
