[BUG?] fresnel scale in phong
6 posts • Page 1 of 1
u3dreal
Post by u3dreal » Mon Nov 27, 2006 8:40 am
Hi all , Hi nick,
here is what i found when finetuning M2I materials
I downloaded maxwell free version to have some to start with.
here is the maxwell result.
and here the indigo result. with same color for diffuse and specular. and some thweaking for weight ( now available in M2I ) plus reverse gamma correction
The result is pretty satisfying i think. :D
But there is one thing i noticed. The highlight at glazing angles is brighter
than the other one and difference is bigger than in the maxwell pic.
If i turn specular color to [0,0,0] then i still get some reflection
at glazing angles.and the hightlight :roll:
Is this correct ?
When setting fresnelscale to 1.0 the reflections get even brighter..
So it seems the fresnel scale only adds more reflection to the specular lobe. is this correct ?? :roll:
Doesn't the fresnel scale weight the diffuse/specular depending on viewingangle ?? Just like ior does in other renderrers like maxwell ??
I'm pretty confused :roll:
Or is this a bug after all ?
cheers
u3dreal ;)
3DSMax/Blender -> Indigo website:http://r3ndr.com
My Indigo Gallery !
u3dreal
Post by u3dreal » Tue Nov 28, 2006 1:09 am
Ok here with the new equation .. :D
without RGC on specular color.. fresnel scale 1.0
The result is very good i think only the reflection is a bit too much especially at 90°...maybe i need to apply RGC to specular color as well..
and here with RGC on specular .. fresnel scale 1.0
Ok now it's really good .. only the reflection at 90° seems to be too bright..it seems indigo assumes [1.0,1.0,1.0] for reflection color at 90°
Ok so my wish would be indigo gets the color for reflection at 90°
form the <specular> element then everything should be just fine..
cheers
u3dreal ;)
My Indigo Gallery !
Post by CTZn » Fri Dec 01, 2006 5:27 pm
Hello u3dreal,
Well, I think it is safe to assume that it is good to have specular and fresnel effects separated, they are not linearly related in every case I believe.
Yes, if the viewing angle is not 0° :)
My reason for posting was: what are you calling RGC ? I can't find this within the whole forums :?
thx
zsouthboy
Post by zsouthboy » Fri Dec 01, 2006 6:06 pm
Reverse gamma correction.
u3dreal
Post by u3dreal » Sat Dec 02, 2006 4:52 am
YES !!!
cheers
u3dreal ;)
Post by CTZn » Sat Dec 02, 2006 9:00 am
Ok, thank you !
Users browsing this forum: Ahrefs [Bot] and 3 guests
