Cindigo 1.1.14 - "instancing terror!"
- PureSpider
- PureSpider
@fused:
Also this annoying "xyz coordinate bug" is still there in Cindigo 1.1.14!
Had you been able to fix this bug yet?* instances inside instanced objects will be ignored (this is going to be fixed)
uhm, i think so, yes.
the "xyz bug" should also be fixed, but i also introduced a new bug(thats kind of unexplainable for me). its easier to work around it tho (its related to null objects in null objects).
but i think youll have to wait for indigo 1.1 stable until this version is released, as there are still a few things to be fixed/improved/changed.
- PureSpider
Perhaps, it was in fact this "new" (related to null objects in null objects) bug, that bothered me, if this one also results in out of alignment geometry, cause the axes of my model hadn't been rotated (all angles are zero), what seems to be the trigger for the "old" xyz bug.fused wrote:the "xyz bug" should also be fixed, but i also introduced a new bug(thats kind of unexplainable for me). its easier to work around it tho (its related to null objects in null objects).
- pixie
I have a massive instance scene and I bump into a problem. After exporting there were missing objects, my solution was to put all the references before the instances then it was all fine and dandy... another thing was that it was crashing heavely when it had instances of complex objects (parenting objects).
> 'I have a massive instance scene and I bump into a problem. After exporting there were missing objects, my solution was to put all the references before the instances then it was all fine and dandy'
I had the same problem couple of times. What do you mean with 'put all references beforce the instances' exactly?
