Test curtains and carpet
delle
Post by delle » Wed Feb 04, 2009 9:38 pm
Hi this is the first shot for a test on curtains and carpet.
Bye
Delle
mrmoose
Post by mrmoose » Wed Feb 04, 2009 10:19 pm
WOW! Curtains are amazing! :shock:
I like them very much.
Carpet is too flat for me.
How did you do the curtains material?
By :)
delle
Post by delle » Wed Feb 04, 2009 10:51 pm
I use two different materials (with different transparency)
- Tenda bianca (more transparent)
- Tendone (less transparent)
Here are the two materials:
<!-- Material : "Tendone (2)" -->
    <material> <!-- IgsMaterialType : "IgsDiffuse" -->
      <name>Material_54_Diffuse</name>
      <diffuse>
        <albedo>
          <constant>
            <rgb>
              <rgb>0.800000 0.800000 0.800000</rgb>
              <gamma>2.2</gamma>
            </rgb>
          </constant>
        </albedo>
      </diffuse>
    </material>
    <material> <!-- IgsMaterialType : "IgsDiffuseTransmitter" -->
      <name>Material_54_DiffuseTransmitter</name>
      <diffuse_transmitter>
        <albedo>
          <constant>
            <rgb>
              <gamma>2.2</gamma>
            </rgb>
          </constant>
        </albedo>
      </diffuse_transmitter>
    </material>
    <material>
      <name>Material_54</name>
      <blend>
        <a_name>Material_54_Diffuse</a_name>
        <b_name>Material_54_DiffuseTransmitter</b_name>
        <blend>
          <constant>0.050000</constant>
        </blend>
      </blend>
    </material>
    <!-- Material : "Tenda bianca" -->
      <name>Material_55_Diffuse</name>
      <diffuse>
        <albedo>
          <constant>
            <rgb>
              <gamma>2.2</gamma>
            </rgb>
          </constant>
        </albedo>
      </diffuse>
    </material>
      <name>Material_55_DiffuseTransmitter</name>
        <albedo>
          <constant>
            <rgb>
              <gamma>2.2</gamma>
            </rgb>
          </constant>
        </albedo>
    </material>
    <material>
      <name>Material_55</name>
      <blend>
        <a_name>Material_55_Diffuse</a_name>
        <b_name>Material_55_DiffuseTransmitter</b_name>
        <blend>
          <constant>0.300000</constant>
        </blend>
      </blend>
    </material>
Bye
Delle
delle
Post by delle » Thu Feb 05, 2009 10:11 pm
Hi, here is a little update.
:wink:
Delle
rgigante
Post by rgigante » Fri Feb 06, 2009 1:33 am
Hi Delle,
in this scene the glass of the window has been removed or is still present?
Great images, R.
delle
Post by delle » Fri Feb 06, 2009 1:37 am
Removed, but seams that Indigo 1.1.16 produces less fireflies..
Delle
rgigante
Post by rgigante » Fri Feb 06, 2009 2:37 am
Thanks Delle,
from my test i still have the same fireflies coming out from 1.1.15 and before..
R.
delle
Post by delle » Fri Feb 06, 2009 2:40 am
Maybe I'm only lucky and no Sun ray intercepts directly the glass...
:wink:
Delle
Post by suvakas » Fri Feb 06, 2009 2:53 am
Carpet seems a bit too small for me.
Nice scene otherwise. :wink:
5OnIt
Post by 5OnIt » Fri Feb 06, 2009 9:49 am
Curtains are spot on... would love to see a wire frame sometime.
I would just increase the size of the carpet and add some wrinkles. It just looks a tad too "perfect".
Post by CTZn » Fri Feb 06, 2009 11:07 am
Nice delle.
I assume that delle experiences less fireflies because he has full control on light energies.
Are you using real world values for emission, delle ?
delle
Post by delle » Fri Feb 06, 2009 10:50 pm
Here are the images requested...
Bye
Delle
Current Indigo render
Opengl color view
OpenGL - Color view.png (680.3 KiB) Viewed 17797 times
Opengl outline
OpenGL - Outline view.png (122.57 KiB) Viewed 17796 times
Curtains wireframe
Curtain wireframe.png (85.33 KiB) Viewed 17797 times
Doug Armand
Post by Doug Armand » Sat Feb 07, 2009 2:25 am
I'd said that is pretty neat - looks quite realistic.
Only comment I have is about the carpet. It looks flat because it appears to be perfectly flat! - maybe try a little bumpage to resemble a real world wear and tear?
and maybe the same for the sofa?
Apart from that I like it. Thanks for sharing the images of your work files - always illuminating :lol:
Doug
Doug Armand
delle
Post by delle » Mon Feb 09, 2009 9:43 pm
Here is an updare after four days of rendering...
I'll keep it cooking for a while...
..than I'll make some changes to the scene..
Bye
Delle
Day version
Night version
Post by Kram1032 » Tue Feb 10, 2009 6:06 am
:shock:
The night version is only lit by the TV and the radio-clock?
They look great :D
