Random exterior
Namiro
Post by Namiro » Mon Feb 02, 2009 7:13 am
and maybe some problems in scale of the model... the tree seems too small
Stur
Post by Stur » Mon Feb 02, 2009 8:34 am
I agree with Namiro. Your render is very good, but it would be excellent with a nicer floor texture.
Olis
Post by Olis » Mon Feb 02, 2009 8:41 am
I agree as well. The stone texture is there as a placeholder until I fins something better. Does anyone have a suggestion?
Your lights stand no chance against the Indigo sun!
Post by CTZn » Mon Feb 02, 2009 8:29 pm
Olis wrote:The pool water is nothing special. It is a subdivided plane
That's weird, that's not how one is supposed to model a water pool but it sure is looking good !
Olis
Post by Olis » Mon Feb 02, 2009 8:38 pm
It works as long as the camera is above the water surface. If I want a picture from inside the pool, I'd have to make it a closed volume.
Post by CTZn » Mon Feb 02, 2009 8:55 pm
Okay, as I said it's looking good...
in my mind an open surface with a specular material applied would render black, I never suspected that cluttering another open volume with it would address that issue...
Post by Kram1032 » Mon Feb 02, 2009 11:52 pm
look at old renders... for some reasons, they do. but it doesn't really look correct, especially, if you use super-accurate water (tabulated spectra ^^)
Post by CTZn » Tue Feb 03, 2009 6:04 am
Right, I runned a quick test and while with the plane setup one can tint the water, it's absorbtion will remain null in regard with depth in water. So it's a good model if you want no absorbtion at all, just tinted water. It renders faster than the realistic model of course.
That was just a parenthesis, I was not sure about what was going on Olis :)
dmn
Post by dmn » Tue Feb 03, 2009 4:03 pm
It seems like the grout border around the grey paver texture tile is wider than the other grout lines? Also, it seems like the grey paver texture could align with the edges of the pool? :D
