I really think that what you refer to is filter -> distort -> diffuse glow in PSqomop wrote: i have a question : are the halo effects on the righ part of the image directly from indigo? due to aperture diffraction or something??
Cinema studio in factory
ahan, yes that s what i guessed too in the beginning. i have french version of PS (i m from france)
what i refer to is in "filtres->rendu>halo". in the french version
seems to match then.
i prefer it without it. i think this kind of effect is convincing in videos when it moves, and does a short apparition, but on an image i find it too artificial, although you did it low.
Namiro
can you tell me what resolution output you set to render it in 15H with yer 1.1.15? because after 8hours,on a similar type of scene, i don t have even half of the final result
and would you mind sharing your settings ? i have a problem with exactly the same type of scene you have done, and i would like to know what is going wrong with my renders
if anyone of you have an answer for that, because i see noone else having the same problem as me
see here http://www.indigorenderer.com/joomla/fo ... php?t=5393
qomop
qomop
of course qomop !
1800x900pixelscan you tell me what resolution output you set to render it in 15H with yer 1.1.15?
Check your light energy...For my image, four lights with a lot of power !because after 8hours,on a similar type of scene, i don t have even half of the final result
Tell me what kind of settings first.would you mind sharing your settings ?
hi namiro
thanks for yer answer!
for the settings, i was thinking about camera settings for aperture and speed, and your lights power/efficacy and tracing method if you don t mind.
I think i almost solved my problem with 1.1.15 but it is just to have an idea of how other people set indigo to see if i use it correctly myself
for the moment, to solve my problem, i use my 1.0.9 for these kind of scene because it seems to work better and really fast on my computer. this can seem really weird... but by the moment it works, let s rock!
thanks
qomop
thanks
qomop
Pibuz, I've got a surprise for you !Where did you find the brick texture? I've always had some problems finding a good one..
http://archiforge.com/browse/1776458308 ... z11307411/
