WytRaven's Robot WIP
Big Fan
Post by Big Fan » Mon Jan 26, 2009 9:02 pm
WytRaven
Post by WytRaven » Mon Jan 26, 2009 9:02 pm
Ono: The nitrile material is posted in the material library if you want to investigate. I commented there that it was darker than it should be and at the time I thought it was just due to the size of the object in the preview scene...
WytRaven
Post by WytRaven » Mon Jan 26, 2009 9:19 pm
Big Fan wrote:http://www.barnhillbolt.com/specs/Metri ... rewsSS.htm :P
I give it away at this point :D
But now that you've mentioned it the outer edge of the cap could use some heavier bevelling which would then force the socket to be adjusted to a smaller diameter...
Primary reference image
