dougal2
by dougal2 » Wed May 14, 2008 4:29 am
The result you see in my render above is from using a very small plane with it's normal pointing in the direction of the light - in this case downwards.
If you could let us know what 3d app you use, I'm sure someone here can talk you through how to set it up.
dougal2
by dougal2 » Thu May 15, 2008 5:56 am
OK, I've rendered the whole lot. 2475 are compatible with indigo.
Anyone got any good ideas on how to display/distribute the renders? they total about 233mb.
by CTZn » Thu May 15, 2008 6:22 am
batch convert, generate page with links to images. Apache style.
by BbB » Thu May 15, 2008 8:35 am
Thanks Dougal. Much appreciated. And thanks to Pibuz for the goodies.
dougal2
by dougal2 » Thu May 15, 2008 11:58 am
No problem, I'm glad I could give my machine a decent job to do ... so many wasted CPU cycles ...
roville_csb
by roville_csb » Thu Jul 17, 2008 2:18 am
Hi! guys is it possible to change the color of the ies light?
by BbB » Thu Jul 17, 2008 2:52 am
I think I've done that successfully in the past, but don't quote me on it...
by Kram1032 » Thu Jul 17, 2008 5:52 am
afaik, IES lights don't include frequency data, just how strong the light goes where.
So, simply using RGB / Blackbody light in the desired colour should work fine.
by StompinTom » Thu Jul 17, 2008 7:07 am
use a very small plane with an Emitter material and load your IES profile into that. remember, Indigo doesnt have "lights" per se, but rather any object can emit light.
using a tiny plane is the most efficient way, though, because Indigo projects the IES profile from a point at the center of each face, in the direction of the face normal. so for a single IES light, you just need one face, therefore a plane.
hopefully in the next release or two there will be a more comprehensive support for all kinds of IES profiles as well as linear IES lights, etc etc.
SpAcEtRiBe
by SpAcEtRiBe » Tue Jan 20, 2009 8:23 pm
can someone reupload ies archive? i can't download it...
by CTZn » Wed Jan 21, 2009 3:57 am
SpAcEtRiBe
by SpAcEtRiBe » Wed Jan 21, 2009 8:16 pm
sorry... i mean the one with preview... the last posted by dougal2
dougal2
by dougal2 » Thu Jan 22, 2009 12:26 am
I still have that file in a backup. If someone can host it, I'll give it to them to host.
by PureSpider » Thu Jan 22, 2009 1:04 am
What size is it?
Users browsing this forum: Google [Bot] and 22 guests
