Indigo 1.1.16
WytRaven
Post by WytRaven » Fri Jan 16, 2009 4:02 am
CTZn wrote:Wyt, maybe delete *.tre files for the bih issue, Indigo may recompute them correctly ?
Ok so I did this and resumed using console. It works but my ms/s is still up at around 52 as it was with bih_tri_threshold 0... If I start from scratch then i get around 24 ms/s so it seems as though something is still awry somewhere :?
I think I'll just curl up in a corner and cry :cry:
...hold the phone! it's dropping slowly....could it be that indigo is just confused by the previous info and is actually going at 24 but will take some time to get the figure right in display?? Oh I do hope so... 8)
Pinko5
Post by Pinko5 » Fri Jan 16, 2009 4:12 am
Tnx ONO!!!
Luca. ;)
Post by CTZn » Fri Jan 16, 2009 5:06 am
Yes, forcibly to resume spp count Indigo has to read the previous rate, wich will progressively reach the initial (fixed) rate. But rendering speed is at max as soon as you resumed, it's just the global ms/s value being progressively updated.
SmartDen
Post by SmartDen » Fri Jan 16, 2009 5:31 am
Thanks Nik!
Logging still not work
Check normals, dude!
Jambert
Post by Jambert » Fri Jan 16, 2009 7:57 am
Thx Ono :D
WytRaven
Post by WytRaven » Fri Jan 16, 2009 3:02 pm
Well I can definitely confirm that in the console version of 1.1.16 Win64bit that both resume and kd-tree bugs are fixed. My render is powering along now :)
joegiampaoli
Post by joegiampaoli » Fri Jan 16, 2009 7:41 pm
Anyone experiencing crashes with some testscenes in linux 32 bit?
I get them as soon as I load a test scene.
BTW: Thx Ono!
Joe Giampaoli
My Indigo Gallery
filippo
Post by filippo » Sat Jan 17, 2009 3:46 am
wonderfull work..Thx Ono
filippo
SATtva_
Post by SATtva_ » Sat Jan 17, 2009 8:37 am
Ono, many thanks for the release. Btw, 15.01 was my birthday. ^___^
* catching more memory alloc failures on init and during tonemapping.
Could this be related to that report?
EDIT: Looks like it's not. Memory footprints of both 1.1.15 and 1.1.16 are nearly the same during rendering phase (actually, 1.1.16 uses a little bit more). I haven't checked tonemapping phase though.
joegiampaoli, which ones? I had a similar issue with ISL due to some Linux Hardened kernel features. Are there any messages in system logs related to these crashes?
Post by Kram1032 » Sat Jan 17, 2009 9:46 pm
yay 1.16 :D
delle
Post by delle » Tue Jan 20, 2009 10:37 pm
Hi, first of all thanks Ono!
Second, I think that this bug (release 1.1.15) has not been fixed in release 1.1.16:
delle wrote:With this Scene (GLEditor.zip) I get this error:
Shader runtime error: No texture with index 0
But the texture "0" is present
I think that this might be an Indigo error... :roll:
Indigo: 1.1.15
Exporter: Custom exporter
Delle
Full details Here:
http://www.indigorenderer.com/joomla/fo ... highlight= (see message Posted: 18 Dec 2008 17:24)
Bye
Delle
SATtva_
Post by SATtva_ » Tue Jan 20, 2009 11:17 pm
Here's another problem. Starting 1.1.16 on the scene (exported with Blendigo 1.1.14) I get this obscure error message:
Warning: failed to decode texture '../textures/metal/scratches_bump.jpg'.
Error: IndigoDriverExcep: SceneLoaderExcep: Failed to load texture '../textures/metal/scratches_bump.jpg' (In element 'texture', around line 75, column 13): ImFormatExcep: Error while reading JPEG file: Bogus message code %d
However 1.1.15 on the same scene with the same texture file works flawlessly (well, except for black triangles). I've attached texture file below.
scratches.tar.gz
Problem texture
(1.92 MiB) Downloaded 289 times
Post by OnoSendai » Tue Jan 27, 2009 1:19 pm
SATtva_ wrote:Here's another problem. Starting 1.1.16 on the scene (exported with Blendigo 1.1.14) I get this obscure error message:
Anyone else experiencing this error?
SATtva: please try opening and saving the JPEG file in another image editor, and see if Indigo gives the same error.
joegiampaoli
Post by joegiampaoli » Tue Jan 27, 2009 1:42 pm
Nope, haven't come across it yet...
Joe Giampaoli
My Indigo Gallery
Grimm
Post by Grimm » Wed Jan 28, 2009 9:04 pm
Thanks Ono,
Now that the library issues are fixed, it works great.
Grimm
Users browsing this forum: No registered users and 103 guests
