Last night I was updating the Maya section a bit in wiki, I'll go further today. I swear the next MtI version is out in 36h max
Strange color points
Right, reinhard tonemapping will detect the disruption of a single atom if there is no other light source. Only Camera and linear tonemapping represent a constant sensitivity to light, they must be used prioritarily (?) when setting lights up !
- PureSpider
oh my mistake, its not due to cauchy - its something else...
Try run the dispersion test scene and see for yourself. Every time I try it I get loads of multicoloured fireflies. (try with aperture diffraction disabled)
Next edit the igs file and change the cauchy to 0 then run it. The fireflies are still there but only in 2 colours.
- PureSpider
It seems that each indigo version previous to 0.9_test1 will render the scene slightly different but looks correct - , while versions 0.9_test1 and onwards renders with those dots - and it gets more intense it later versions.
So which version is correct? Or is there still a bug here? (or just operator error?)
- indigo1.1.15_dispersion_test.jpg (101.29 KiB) Viewed 5453 times
- indigo0.9t1_dispersion_test.jpg (97.13 KiB) Viewed 5453 times
- indigo0.8_stable_dispersion_test.jpg (60.91 KiB) Viewed 5453 times
- indigo0.6t1_dispersion_test.jpg (100.33 KiB) Viewed 5452 times
- indigo0.5t7_dispersion_test.jpg (189.29 KiB) Viewed 5454 times
- indigo0.4_dispersion_test.jpg (114.06 KiB) Viewed 5454 times
ah, excellent thanks fellas, I guess that solves it - it's been awhile and I completely forgot about those bidir issues
edit: with a 10,000 spp render
but not enough rainbow
- im1231269167.png (199.11 KiB) Viewed 5357 times
Sinister: in the last release I fixed (reverted oops) both camera aperture and efficacy scale, maybe that helped if you used the meshlight settings I posted and corrected the glass scene scale
Was bidir on for your test ? By the way are you talking about the dispersion test scene or your glass scene ?
It's nice to have done these tests Sinister, but maybe you did not understand exactly how advanced options works in MtI.
Whenever Mti Use Adv Opt is off, bidir and mlt settings from the UI are discarded. The following only are then written to igs,
... and Indigo will use the default renderer values defined in inifile.txt (Idigo app dir, metropolis off, bidir on), every time advanced options are off.
So if you really want to test rendering combinations, leave advanced options ON in MtI and tick/untick mlt/bidir in ui.
I can explain again, or further if you need.
By the way the third shot is a rare thing o.O It's mlt only.
<renderer_settings>
<width>
<height>
<super_sample_factor>
<logging>
<image_save_period>
<display_period>
<save_igi>
<save_tonemapped_exr>
<save_untonemapped_exr>
</renderer_settings>
output truncated horizontally for readabilitySo if you really want to test rendering combinations, leave advanced options ON in MtI and tick/untick mlt/bidir in ui.
