wishlist: automatic .png transparency support
- kwistenbiebel
Hi all,
At the risk beating a dead horse, I would want to ask whether rendering .png transparency is on the to do list for skindigo. I mean without having to point to clipmap textures.
I just ask as both Podium and Fryrender support it by now (Vray not yet afaik).
What do you think?
What do you think?
Hi kwistenbibel, you know I'm not a Skindigo user but I believe that the horse is rather not born yet !
Indigo won't read those images, if you tried already it would complain about pixel depth being inadequate. So using png with embedded alpha channel in Skindigo would mean splitting the images with a third party software afterwards in all cases, at least until Indigo supports transparent png's...
It's first about the renderer, the exporter follows.
- kwistenbiebel
- kellpossible
What language is Skindigo written in? If there is an easy way to load a png in said language Skindigo should load png textures and then write out the alpha chanel to a png image and use that as a blend map with a null mat. It would not be hard to do in my native language, Java, but I don't know if it is possible in Skindigo.
- kellpossible
at the moment you have to make a clip map for the trees by extracting the alpha map from the png and saving it as a black and white jpeg, then put that jpeg as external with the same uv coordinates as su(if your using the new version), or with the old version just load it into sketchup with the same uv coordinates. You might already know this, but I said how to just in case!
- kellpossible
