orange juice
orange juice
How to make orange juice?
Thank you
Thank you
Hey,
I made one in the past:
You can get the material itself from this link (second post from the top):
http://www.indigorenderer.com/joomla/fo ... &start=135
The issue with this mat is, that my scene was too small. (only a few cm's). So you may have to change some parameters to make it work for normal sized scene or use 2cm high glass
Tony, notice how "<value>20.0</value> " is between "<scattering_coefficient_spectrum>" and "</scattering_coefficient_spectrum>." The way most script language works, this means that 'value' is somehow related/ subordinate to "scattering_coefficient_spectrum." So search in the manual for "scattering_coefficient_spectrum" and you will find on page value to be the number of meters^-1
...although this still doesn't explain much
I have done tests and I note that with low value the liquid becomes transparent.
As you climb up the values becomes opaque, as more dense.
With a value of 200 seems custard or flan.
This is what I asked.
The second question: how change in blendigo the value of gamma.
- value200.png (981.26 KiB) Viewed 10509 times
- value60.png (1014.76 KiB) Viewed 10511 times
- value30.png (998.75 KiB) Viewed 10511 times
- value15.png (991.75 KiB) Viewed 10511 times
- value5.png (968.85 KiB) Viewed 10513 times
