Some questions about the Indigo.
victorphellipe
Hi! I'm a Blender User and I have a couple of questions!
What is the relation between the Indigo, the video card and the Processor?
I saw, some time ago, the Indigo used more the video card than the processor. It's true?
And the Sun... Can I reduce her Energy?
I'm making a scene and I wanna a blue ilumination. But, if a let the Sun with 70º the Sunlight is too strong. And if I let the sun with +/- 30º the ilumination is too Dusk. Any ideas?
- PureSpider
Re: Some questions about the Indigo.
Nope, Indigo only uses the CPUWhat is the relation between the Indigo, the video card and the Processor?
Didn't really get what you meant with the °... the height of the sun?And the Sun... Can I reduce her Energy?
You actually can change the light emitted by the sun by changing the turbidity
Blue illumination, however, is not possible, use a spherical mesh emitter with enough power and far enough away from your scene for that purpose...
victorphellipe
- PureSpider
Wrong.
Turbidity changes, how much light gets scattered around the sky.
Turbidity 0 means, the SKY is black (-> dark) but the sun has actually MORE strenght. The light is focused on (more or less) a single point, while with higher turbidity rates, it gets scattered over the whole sky, so the light gets more diffuse.
Though, the model isn't meant to be used with non-earthlike values... Don't go beyond (what was the value?) 6 (I think), which means a highly polluted air. Clear sky is ~ 2.
At turbidity 20 for instance (tried that already), the sky turns all green...
Light is (not REALLY noticably) more diffuse but it's hardly possible to find a matching whitepoint.
I guess, turbidity defines two things: which wavelenghts of and how strong light gets scattered... So, turbidity inf would mean a perfectly diffuse grey sky. (Even at night, the light is everywhere)
What you can do instead (both changing brightness and, even if highly unreal, colour) to use Layerlight. Sun (or any background light) currently always is on Layer 0.
Guessing, that 0° and 180° means horizon, I'd say, noon ("perfect" noon, as only seen on a single spot per day, somewhere between the tropics of Cancer and Capricorn...) is at 90°.
Do NOT use angles beyond 180° or before 0°, because the sky model also isn't realistic for night situations. For example, if you put the sun into the nadir (270°/-90°), you'll get a deep purple sky and not a more or less black one.
victorphellipe
I feel weird PureSpider say that the higher the value, the stronger would be the Sun.
The LayerLight only avaible in what version of Indigo? I use the stable version (1.0.9).
Last night I got a result where the sun is not so strong, but is too weak! But I tried no more, I made a render in Vray went to sleep and left the Indigo rendering the scene.
I'll try a few times and if I get a good result I say here.
Thanks for all information!
- im1227927419.png (1.32 MiB) Viewed 13674 times
- PureSpider
- Borgleader
I cant find light layers in Blendigo 1.1.13Kram1032 wrote:Yeah, that'll be a lot faster
Simply try the newest Indigoversion (1.1.4, currently) and the newest exporter (1.1.3 for Blendigo). You'll find some nice options in the GUI with one being the layer lights.
- Borgleader
- PureSpider
- Borgleader
I know. But I don't want to bother Smartden too much. He's already doing great with Blendigo and he works hard to fix the bugs. We'll get light layers when he gets there.PureSpider wrote:Actually Indigo is able to, go complain to your blendigo writer about that blendigo isnt yet
- Borgleader
Users browsing this forum: No registered users and 52 guests
