Simulating a planets atmosphere
- Borgleader
- Borgleader
+1
Oh, and just so you know: There is a feature, which might be helpful, here...
It's an extremely slow one, but it'll help you with the sky, seen from outer space. The main problem will be, that you'll need to model all the stuff "true sized" and also the distances correct...
http://www.indigorenderer.com/joomla/in ... emId=20229
The stars are postprocessed! But earth and moon are totally correct
you'd need to write the syntrax yourself most probably... A cool but due to time consume rather unused feature of Indigo...
- PureSpider
You can aproximate its ior as 1, and absorbtion as extremely low (low, like you are gonna try a low value and see, either what... omg). Ah, the athosphere is more blue than, I don't know, grey or green, birds have their belly down when they are alive and fishes have it way up when they died. Anything else neo. ?
- Borgleader
epicCTZn wrote:You can aproximate its ior as 1, and absorbtion as extremely low (low, like you are gonna try a low value and see, either what... omg). Ah, the athosphere is more blue than, I don't know, grey or green, birds have their belly down when they are alive and fishes have it way up when they died. Anything else neo. ?
- Borgleader
Hi neo0,
I did something similar here:
http://www.vimeo.com/1785327
I used a real satellite image (MODUS data) for the texture. I then used Blender's composite nodes to blur the image and composite it behind the original to create the atmosphere. I think I also color corrected the blur to be more blue.
Grimm
Users browsing this forum: Google [Bot] and 57 guests
