the problem is fixed as well a lot of other. i also wewrote the whole instances part. i just need some more test and i 'll release it. if anybody have fun to test it too, welcome on the irc channel or icqOlis wrote:Sorry I haven't responded on my error. The scene is quite large.
I looked up the default_meshes.xml and found this:
It doesn't seem like Indigo accepts that.
Blendigo for v1.1.13
Check normals, dude!
- Borgleader
The version where the #IND00 problem is it the one in the first post? Because I'm getting the same error
And well...fixing it is taking a long time because...there are so many friggin vertices in the scene notepad++ is taking like....5-10 min to replace them (at least)
I have a scene ready for you but ...it's the .blend because the igs is like 30 Mb. (even the scene if i use blender's compression AND .zip it is like 6.5Mb)
I'll send it to you by PM if you want
P.S: If you want me to test your new script on my scene I gladly will
- aleksandera
- Borgleader
Hello,
first I must thank for all work done on Indigo and Blendigo (this is my first post to this forum and I feel, that I should express some gratitude, not only post bug report
And now the problem: blendigo crashes when I try to select material with image texture from "Blender mat" list in "Materials" tab. Dump to console says:
Trying with stock Blender 2.48 on Debian Lenny.
File "/home/disnel/.blender/scripts/blendigo_v1113.py", line 3706, in buttonEvt
materialButtonEvt(evt) # zuegs: added material editor
File "/home/disnel/.blender/scripts/blendigo_v1113.py", line 1579, in materialButtonEvt
readWriteMaterial(activeMaterial, 0)
File "/home/disnel/.blender/scripts/blendigo_v1113.py", line 458, in readWriteMaterial
convertMaterial(m)
File "/home/disnel/.blender/scripts/blendigo_v1113.py", line 418, in convertMaterial
mat.properties['indigo'] = d
RuntimeError: invalid element in subgroup dict template!
Users browsing this forum: No registered users and 107 guests
